Hallo, how can i change the Parameter 14 of the Fibaro RGBW Controller, the Parameter ist not availible on my zway controller.
I con control the colors withe the dimmer switch for red, green and blue, but i can not control the colors with the color dimmer, the dimmer change the color to blue and green and no other color.
Fibaro RGBW
Fibaro RGBW
- 2017-01-16_21-35-05.png (159.87 KiB) Viewed 3366 times
- Z-Wave Support
Re: Fibaro RGBW
Go to Expert Commands, then go to Configuration.
At this point you can get the status via Get and change the parameter with Set.
A review of the setting can be done by clicking on Configuration, you can see the setting has been adopted. Green means current. Red means it is no longer actual.
Z-Wave Support
Z-Wave Support
