raZberry Firmware Serial API UPgrade Impossible?(Solved)
Spirit78
Post by Spirit78 »
I have being in contact with support and they ask me to upgrade the controller board to 5.07, Now I have 5.04, in the expert UI.
But it seems to be impossible to do an upgrade? It just spinns and reload the page after a while and the firmware is the same again?
Do I have to have a firmwarefile to do an upgrade, and if so, whre do I find that file?
//Andreas
diemue
Re: raZberry Firmware Serial API Version UPgrade Impossible?
Post by diemue »
After the upgrade you must power off / power on the raspberry
Spirit78
Post by Spirit78 »
Thanks for reply, but that doesn´t help
Have tried it several times....
If it would be possible, could I ask you to take a look at the picture and se if the same or someting else is written on the bottom of the controller info page on your z-way
SerialAPISetup Not Implemented.png (124.6 KiB) Viewed 17563 times
Spirit78
Post by Spirit78 »
Finally i got 5.07 in.
After several powercycles and tries with the update. :D
Bastldd
Re: raZberry Firmware Serial API UPgrade Impossible?(Solved)
Post by Bastldd »
Hey Spirit,
How did you do this? I have the same problem.
Bastl
AlphaX2
Post by AlphaX2 »
Same here, how do you got it? Also the thing is, since the update it seems Razberry is not getting the wakeup call of battery devices, due to this my thermostats are not working as they should. :-/
Spirit78
Post by Spirit78 »
I did:
1. sudo shutdown
2. Power Cycle
3. When started up whent in directly to Expert mode from WebUI and upgraded
I took about 3 times, so if it was the amount of tries or something else, I don´t know :roll:
But finally it worked
AlphaX2
Post by AlphaX2 »
Okay I've got 5.07 but missing the SDK version in ExpertUI, but Firmware is officialy 5.07 now. Is the missing SDK a problem, at least it seems to work - but problem with thermostats still present. :?
missing SDK is just a missing text mapping. dont worry
