z-way-server does not start in Stretch
It looks like there isn't a package in Stretch for libssl1.0.0. Are there plans to upgrade to libssl1.0.2?
Re: z-way-server does not start in Stretch
It is pretty hard to support many variants of libraries. May be once we see that this version will become part of Jessie
Paltos jessie will not get updated libssl version, jessie is slowly going to die the same way as wheezy did.
Stretch is the new raspian base and in the forthcomming month z-way should be updated to support it as jessie would not get security updates as normal debian do.
zway libraries need libssl1.0.0 but raspbian stretch give libssl1.0.2.
a workaround consist to download and install this library (from raspbian jessie):
Waiting for razberry update it's code to support libssl1.0.x...
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
The code supports a more modern library, but just switching to the new one will kill Z-Way on all Jessie. So we need to make some workaround here. Still thinking how to proceed forward...
Just compile it twice (one for Jessie and one for Stretch) and load as needed correct z-way-server tarball.
Otherwise you will see more and more frustration coming up from your new users and old one those who decided to do upgrade.
Hi Polto,
It's no problem at all with a modern build system - I'm doing it daily.
Regards,
Lars
The right solution would be to build proper Debian packages and add them to a repository - like Bintray. You should build two different packages, one for Jessie and another one for Stretch - apt-get would then choose the right one automatically.
Regards,
Lars
Best regards,
Lars
Lars
yea i just upgraded to stretch, would be cool to get it working there. im wrestlhing with libarchive as well
The standard Raspberry installer 'NOOBS' no longer offers Jessie as an option and now only supplies Stretch. Trying to install the jessie library above only resulted in Illegal Instructions when trying to launch the server. This is now an issue for me as a power blip corrupted my instance and I need to reinstall :< . With Jessie on the wane please consider building a Stretch-compatible edition.
In fact, https://www.raspberrypi.org/downloads/raspbian/ does not offer Jessie at all anymore.
You can find the images here...jhmartin wrote: ↑14 Nov 2017 07:49The standard Raspberry installer 'NOOBS' no longer offers Jessie as an option and now only supplies Stretch. Trying to install the jessie library above only resulted in Illegal Instructions when trying to launch the server. This is now an issue for me as a power blip corrupted my instance and I need to reinstall :< . With Jessie on the wane please consider building a Stretch-compatible edition.
http://downloads.raspberrypi.org/raspbian_lite/images/
