z-uno and SmartThing issues
RobertL.
Post by RobertL. »
I'm new to z-uno and z-Wave and SmartThing, but I'm an experienced Arduino user.
I have spent the last couple of days experimenting with the Z-UNO connected to my SmartThing hub.
I understand that this is not plug and play so I've been reading a lot.
So far I have been successful in controlling the z-uno ( switch, dimmer etc) but nor the other way around, from the z-uno to other devices.
My first project is to make a 4 button remote using z-uno to control some devices on my z-wave network.
The 4 button example on the Arduino IDE should have been a good starting point but i'm unable to get it to work,
I probably need to write a device handler on my smartThing hub in order to be able to get it to do what I want it to do. I'm not there yet!
I tried the simple MotionSensor example but it pairs up as "Z-wave Device Multichanel" rather than a Door/Window sensor. Wont work
Frustrating!!
Does anyone have a Device Handler for SmartThing hub that I could use with the 4 button example?
Also, if someone knows how to force pairing in a 'motion detector' mode?
Robert
bribert
Re: z-uno and SmartThing issues
Post by bribert »
Hi Robert,
Did you find any solution to your SmartThings setup? My project is very similar to your's.
I am trying to use the Z-uno as a 4-contact interface to read relays from my Vista alarm system, so I need SmartThings to see the Z-Uno as one device with 4 contacts. I set the Z-Uno up for 4 channels, with different "getters", but the only "report" is "SwitchMultilevelReport(value 99)" or value 0, which is issued only when the first relay closes or opens (none of the other 3 relays).
I cannot find any other device handler that even allows it to read it as a single "contact", never mind 4.
Let me know if you, or anyone else, has a solution.
I too am new to Z-Uno and Z-Wave, with some C experience.
Thanks a bunch!
Brian
RobertL. wrote:
29 Nov 2017 20:03
Frustrating!!
Robert
RobertL.
Post by RobertL. »
Hi Brian,
I was only trying to turn on a light connected to the smartThings hub, with a button on the zuno.
I tried every sensor example on their web site and none works.
I probably need to write a Device Handler but it's beyond my knowledge.
I'm waiting for the people at Z-wave.me to help me with a solution.
bribert
Post by bribert »
Hi Robert,
Thanks for the feedback. If you do get any other info, or can write anything up, let me know.
I will keep searching!
Thx,
Brian
RobertL.
Post by RobertL. »
Can you post your Arduino code?
daedalusminos
Post by daedalusminos »
I'm no Zuno expert and I'm no SmartThings expert, but I'm a dabbler in both.
I believe there's a number of ways to achieve your end result varying in complexity and difficulty.
The easiest is to go out and buy something like an Aeotec Minimote for £50+ but you've bought a Zuno so probably want to put that to good use performing the same task. To emulate the minimote I believe would require associations in SmartThings to enable the Z-Uno to communicate directly to the actors (receivers) - that's beyond my knowledge.
You can however perform a similar function using the hub and smartapps, 4 switches could be realised as 4 binary sensor channels or a single multi-level sensor channel, but both will require a custom device handler. SmartThings have good online documentation for writing device handlers.
It's easy to demonstrate a single switch using the 'Simple Binary Sensor' Z-Uno sketch and the built in SmartThings 'Z-Wave Door/Window Sensor' device handler.
RobertL.
Post by RobertL. »
Thank for your response.
I finally was able to make my Zuno ON and OFF buttons work to turn on/off my bedroom light. I can't dimm but for now i'll live with that.
I used the window/door sensor sketch along with the "Z-wave motion sensor" device handler with only the fingerprint modification.
When I try to use a multi level sensors, the Zuno pairs as a window sensor on the hub, so nothing works.
It would be nice for z-wave.me to provide the device handlers for their examples in order to make them work.
Also, I find it strange that I can buy a Leviton dimmer, install it and make it work without any device handlers.
If zuno could provide the codes to emulate a generic dimmer, it would certainly simplify our lives.
daedalusminos
You can always change the device handler that SmartThings allocates to device - on the browser interface edit device and change the 'type'.
Because Z-Uno doesn't have a fixed function, generic drivers don't always fit the bill exactly.
It may be picking up a generic device handler - you can check in the device info.
I now have a SmartThings box in my hands. Hope we can do more tests and even make handler generator to help SmartThings users to use any type of Z-Uno sketches. Hope we can finish it by 7th if Jan
daedalusminos
An event handler generator sounds excellent!
