Raspberry Stretch Support
aliyahbrown
Re: Raspberry Stretch Support
Post by aliyahbrown »
This is exactly what I’ve been looking for. It solved very quickly the problem I was having.
temp
Post by temp »
aliyahbrown wrote:
14 Jun 2018 12:53
How???
DJay
Post by DJay »
Hi Guys, I hope you can help and appreciate the time you are investing.
I'm using a Raspberry Pi 3 B+
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
I installed
wget -q -O - support.zwave.eu/libs | sudo bash
then
I can reach the login of Z-Wave but when I try to add a device I always get an error popup.
SmartHome UI - ERROR
Unable to load data
Also switching to ExpertUI shows up an Error message.
Z-Wave Expert UI - ERROR
Communication or binding error! Please login again or check system connectivity.
Adding or excluding a device doesn't work and besides the the error messages it's doing nothing. :(
When I run again
I now only get the Message "Raspbian Stretch system detected"
I hope you can help a newbie to get z-wave to work.
Thank you very much in advance.
Bildschirmfoto 2018-06-27 um 22.16.39.png (34 KiB) Viewed 12818 times
Bildschirmfoto 2018-06-27 um 22.17.30.png (69.53 KiB) Viewed 12818 times
Bildschirmfoto 2018-06-27 um 22.18.19.png (52.68 KiB) Viewed 12818 times
Z-Wave Support
Post by Z-Wave Support »
We have investigated the problem.
We think, we have found the issue.
Please start following command with SSH and try again.
(sudo apt-get -qy install libarchive13) && (sudo ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so.13 /usr/lib/arm-linux-gnueabihf/libarchive.so.12)
sudo reboot
Best regards
Z-Wave Support
michelknops
Post by michelknops »
I run the exact same setup and executed your suggested instructions, here is what I get:
pi@raspberrypi3:~ $ (sudo apt-get -qy install libarchive13) && (sudo ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so.13 /usr/lib/arm-linux-gnueabihf/libarchive.so.12)
Reading package lists...
Building dependency tree...
Reading state information...
libarchive13 is already the newest version (3.2.2-2).
libarchive13 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
ln: failed to create symbolic link '/usr/lib/arm-linux-gnueabihf/libarchive.so.12': File exists
Thanks for assisting further.
Kind regards,
Michel.
Please try to re-install. We have fixed this
Vertigo76
Post by Vertigo76 »
Hi all.
Idem, i have the same problem with same configuration. I'd try the command line :
but nothing change :
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
libarchive13 is already the newest version (3.2.2-2+deb9u1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
ln: impossible de créer le lien symbolique '/usr/lib/arm-linux-gnueabihf/libarchive.so.12': Le fichier existe
I try reinstall and same effect.
Please can you help me to solve this problem?
Within next week we plan to set up Rapbian repository
Vertigo76
Post by Vertigo76 »
Hi all,
The problem persist today whith clean install.
