OMG..... OMG...... OMG.....
This very thing was doing my absolute head in a few months ago - totally and utterly doing my head in. It made so little sense and I got so %^&*#^$# with it that I reverted to using old fashioned relays instead of the optocouplers.
So it was a bug with the Z-Uno all that time...?
New 2.1.4 beta
Re: New 2.1.4 beta
No all the time, some pin works, other not.
No need to pass by relay, a pullup resistor to 3.3V suffice.
The electrical schema is : But it overloads everything!
Eric.
Eric.
Re: New 2.1.4 beta
First of all. It's a software problem. I hope we could resolve this in the next beta, but it's a good practice to use 100KOhms pull-ups to economy power for battery supplied devices instead of internal pull-ups (about 10 KOhms).
I misunderstood what do you mean about "overload". It have to work with 4.7K normally. If you have some issues with it, please report.
Alex.
Alex.
Re: New 2.1.4 beta
Big thank for your answer. really nice.
I meant by "overload" that it is the electrical schematics that will have to have more resistance for each input. It's only that.
No electrical problem. And I confirm that with 4.7K external pull resistors all inputs work perfectly.
I'll wait for your update, just that will allow me not to redo all my drawings.
and I can simply test with my schema at least 15 inputs, if you want.
Really thank you for your listening and impeccable follow-up, and really good job with this z-uno.
I have some problem with incude with eedomus box and i contact them for this issue.
The z-uno is detected instantly but the channels are poorly paired. and the number of channels that works is never the same.
I have test with 15 channels and it's very delicate for include the 15 channels.
We get there but it's very very long
Eric.
Eric.
Re: New 2.1.4 beta
I found a another issue with the compiler and S2 security.
The burning of the bootloader is going very well, and when l load the program to the z-uno we have a mismatch error.
I did the test with compiler 1.6.5 and 1.8.5 and it's the same problem.
It works very well with version 2.1.3.
With 2.1.3 : With 2.1.4 : Is there anything else to do with 2.1.3?
Param : Thank.
Eric.
Param : Thank.
Eric.
- 2018-07-11 (3).png (37.5 KiB) Viewed 15935 times
- 2018-07-11 (2).png (45.13 KiB) Viewed 15935 times
Re: New 2.1.4 beta
Hi, we work on the pullup issue. S2 issues was in the first beta. Could you check that you use "the last" beta and have this issue too? I couldn't reproduce it on my build.
Thank you! You really help us a lot!
Alex.
Alex.
Re: New 2.1.4 beta
Really with pleasure, this z-uno is great. And thank you for all these developments.
Great for pullup resistors, I hope it will not be too complicated.
For S2 issues, I just reproduced the problem with the latest beta (by remove all from packages/Z-Uno & staging/packages and reload board from test-ucxx repository). The compiler is 1.8.5.
I Restart Arduino IDE.
I change the card type, the frequency (europe), the security (S2) and the programmer.
I upgrade the bootloader first and ok.
I upload the sketch just after and error.
it does not matter to me because I'm not going to use security, but maybe it can happen to someone else
Thank you for your reactivity
Eric.
Eric.
Re: New 2.1.4 beta
Hello!
I have problems with the BatteryHandler. I can't FLIRS and an own battery handler:
--> error: member reference type '_xd_ZUNOChannelHandler_t' (aka 'ZUNOChannelHandler_s') is not a pointer; did you mean to use '.'?
To verify it, I added my lines above to the example "simple switch":
is this a bug or am I doing something wrong?
Thank you guys!
ZUNO_SETUP_BATTERY_HANDLER(getBatteryVal);
byte getBatteryVal() {
// 100= "> 12,8" bzw. 0 = "< 11.5"
byte percents = 99;
if ( percents > 100 )
percents = 100;
return percents;
* That is a Simple Sensor Multilevel example
* It measures the value on the potentiometer
* And sends report to the controller if changed
// LED pin number
#define LED_PIN 13
// Last saved LED value
byte currentLEDValue;
// next macro sets up the Z-Uno channels
// in this example we set up 1 switch binary channel
// you can read more on http://z-uno.z-wave.me/Reference/ZUNO_SWITCH_BINARY/
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(getter, setter));
byte percents = 99;
percents = 100;
return percents;
void setup() {
pinMode(LED_PIN, OUTPUT); // setup pin as output
void loop() {
// loop is empty, because all the control comes over the Z-Wave
// function, which sets new relay state
// this function runs only once the controller sends new value
void setter (byte value) {
// value is a variable, holding a "new value"
// which came from the controller or other Z-Wave device
if (value > 0) { // if greater then zero
digitalWrite (LED_PIN, HIGH); //turn LED on
} else { // if equals zero
digitalWrite(LED_PIN, LOW); //turn LED off
// let's save our value for the situation, when the controller will ask us about it
currentLEDValue = value;
// function, which returns the previously saved relay value
// this function runs only once the controller asks
byte getter (){
return currentLEDValue;
Thank you guys!
Re: New 2.1.4 beta
Looks like a bug. We will check it
Re: New 2.1.4 beta
Is it possible to supply a string/char value when setting up channels to describe/setting a name because currently I'm only getting "Z-wave.Me..." names. Or have I missed a release with this feature?PoltoS wrote: ↑02 Jun 2018 19:22This build introduces new channel types and cool features.
You can get it from our test repo: https://z-uno.z-wave.me/files/z-uno/tes ... index.json
What's new:
New featuresBug fixes
- If only one channel, MultiChannel will be supressed (Command Classes outside channel will represent your single channel)
- Three new channel types: Color Switch, Thermostat and Door Lock
- Handling of incoming reports from other devices. Handled reports are Basic/Sensor Binary/Alarm/Sensor Multilevel/Switch Binary/Switch Multilevel/Battery/Meter.
- New inclusion mode: double click for unsecure inclusion, triple click for secure (as it was before). New security parameter added to zunoStartLearn(timeout, secure)
- Two new functions: tone() and noTone()
We are starting two weeks beta period and then we will make a public release.
- Fixed multiple ADC influencing each other
- Fixed OTA (broken since 2.1.3)
- Fixed interrupts handlers inside libraries (was broken since 2.1.3)
- Fixed compiler diagnostic messages if a too big sketch is uploaded. Before it was silently ignored.
