Google Home integration
Are there any plans to integrate zway in google home?
- Z-Wave Support
Re: Google Home integration
coming soon...
Best regards
Z-Wave Support
coming soon...
Best regards
Z-Wave Support
Hi.
When it will come the google home integration ?
I just moved from jeedom to this software. And I'm looking for some stuff.
How to create url request from outside my home internet to control my zwave network. It's there a possibility ? Wich add-on ?
Also, are there an add-on to control my esp-easy controllers ? ??
And any way to create virtuals buttons that will check if the device is online (connected to Internet with an ip)???
Thank you!!!!.
Thank you!!!!.
viewtopic.php?f=3425&t=25518#p70659
viewtopic.php?f=3422&t=24579
Check if what device is connected to the internet?
After upgrading from version 2.3.4 to version 2.3.8 I just found that the Google Home App is available. I tried to enable it, bug got the following error message: SmartHome UI ERROR: Unable to update data
What are your experience with the Google Home app? Has somebody got the same error and could you resolve it?
Lordringo121174
You are not alone. I hhad the same issue than you!!!droll wrote: ↑24 Nov 2018 11:34After upgrading from version 2.3.4 to version 2.3.8 I just found that the Google Home App is available. I tried to enable it, bug got the following error message: SmartHome UI ERROR: Unable to update data
I had the same issue. When can we expect this integration
Yes same issue here. It would be nice to have this so I can remove the ugly extra bridge with OpenHab.
