RaZberry V1 with latest firmware won't work with OZW
khavusr
Post by khavusr »
I've been running with a RaZberry v1 top hat card which I got a bit over 2yrs ago and during this period I've never touched any firmware updates or any other updates for that matter. When testing z-wave server I thought of updating the firmware, boot-loader, etc, which works out fine and as well the z-wave server works as it should. But, when going back to Domoticz which utilize Open Z-Wave for z-wave implementation it finds the RaZberry controller but I can't interact or add/remove any z-wave devices. So seems that there is an issue with OZW with never firmware's.
So, my question, is that where can I find a list of older firmware since I need to downgrade the RaZberry card to a level so that OZW works again.
Re: RaZberry V1 with latest firmware won't work with OZW
Z-Way allows to downgrade the firmware too.
But OZW should not have any problems with brewer firmwares
khavusr
Post by khavusr »
Yes, aware that I can downgrade, but I need to specify which version that I want to utilise and I can't find any list of old version to be able pick an older version to try out. Where would I be able to find such information?
micky1500
Post by micky1500 »
you can find the list here:-
https://storage.z-wave.me/z-way-server/
upgrade or downgrade choosing a name in this format v2.3.6-rc8
khavusr
Post by khavusr »
Thanks for the link but isn't this link only containing primary files for Z-Way; what I'm looking for is the versions and firmware files for the RaZberry v1 top hat itself and not Z-Way server platform.
Check here (change the version from which you need to update):
https://service.z-wave.me/expertui/uzb/ ... rCRC=35498
File names are relative to this URL.
You can also check this crazy graph: https://service.z-wave.me/expertui/uzb/graph.php
khavusr
Post by khavusr »
Excellent! Will give this a try.
