razberry v2 shield problem (dead?) after firmware update
BugHoarder
Re: razberry v2 shield problem (dead?) after firmware update
Post by BugHoarder »
Forgot i was still running on v.2.8.1. After i updated to v.2.3.8 the logs began updating again. Same error, logs show:
[2019-05-23 11:13:18.427] [D] [zway] Opened device: /dev/ttyAMA0
[2019-05-23 11:13:18.427] [D] [zway] Worker thread successfully created
[2019-05-23 11:13:18.427] [D] [zway] Worker thread entry point
[2019-05-23 11:13:18.427] [I] [zway] Adding job: Get controller info and supported function classes
[2019-05-23 11:13:18.437] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2019-05-23 11:13:18.639] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2019-05-23 11:13:18.639] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2019-05-23 11:13:18.840] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2019-05-23 11:13:18.840] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2019-05-23 11:13:19.042] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2019-05-23 11:13:19.042] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2019-05-23 11:13:19.042] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2019-05-23 11:13:19.042] [C] [zway] Get Serial API Capabilities returned zero.
[2019-05-23 11:13:19.042] [I] [zway] Removing job: Get controller info and supported function classes
[2019-05-23 11:13:19.052] [D] [zway] Worker thread exit point
[2019-05-23 11:13:19.052] [D] [zway] Worker thread successfully finished
[2019-05-23 11:13:19.063] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2019-05-23 11:13:19.083] [I] [core] Error: Bad data - communication failed
[2019-05-23 11:13:19.084] [I] [core] Tried 5 times without success. Stopping tries.
[2019-05-23 11:13:19.087] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Attached new logs from var/log/z-way-server.log
z-way-server.7z
(22.12 KiB) Downloaded 664 times
Please check config.xml to set log-level to 0
BugHoarder
There is no config.xml file on my raspberry. Tried searching for it with sudo find but didn't get anything.
In which folder would it normally be located?
/opt/z-way-server/config.xml
BugHoarder
Found it!
log-level was already set to 0
<config>
    <automation-dir>automation</automation-dir>
    <log-file>/var/log/z-way-server.log</log-file>
    <log-level>0</log-level>
    <debug-port></debug-port>
</config>
BugHoarder
Did you have anything else for me to try? The issue is still there. Still get the same error message, the razberry cant include anything...
projectile25
Post by projectile25 »
Hi PoltoS
sorry but another one dead Razberry2 board after firmware update,
ZMEERAZ2, rev.2.1 S/N 26.18.01 - on the white label
HW Rev. 2.0 - 11/04/2018 - on the board
Z-Way version v3.0.0
Now all LED are bright. No power loss by update. The whole update process looked fine ,no error message or something wrong .
zwaylog.tar.gz
(366.64 KiB) Downloaded 593 times
perf
Post by perf »
PoltoS wrote:
21 Feb 2019 00:22
The problem is identified. Currently we do not see any options to upgrade except for returning then back to us. The problem comes from the factory and was not found during QC tests. We are working on other options. Only blue boards are affected
Currently we do not have any workaround. We are discussing this with contractor
Hi Poltos,
do you have any news regarding this issue?
How to do firmware upgrade for a blue-board RazBerry?
Blue boards were manufactured by our partners and have an issue with upgrade. Some to them gets bricked. Some are okey. You can not guess it until.you do the upgrade :( so just swap it to a new one under warranty
