New 2.1.5 beta
p0lyg0n1
Re: New 2.1.5 beta
Post by p0lyg0n1 »
1. The red led blinks in rescue mode in 2.1.5b2. It's ok. We do it to identify rescue mode.
2. You have to include in the normal mode. In the rescue mode the NIF will be cropped because you code haven't started in this case. To include the sleeping device just click once to wake it up and then click twice fast. To make "the life easier" you could add the small delay before you send device to sleep. I recommend the value about 1000ms. For example:
void setup(){
	bool have_to_wait_for_input = FALSE;
	// the button was pressed. We save the state here 'cause your setup code could be too long to catch the button after it.
	if(!digitalRead(23))
		i_have_to_wait_for_input = TRUE;
	// --- YOUR SETUP CODE
	if(have_to_wait_for_input){
		delay(1000);
rishamee
Re: New 2.1.5 beta
Post by rishamee »
Ok, thx!
I wasn't aware that inclusion should be done in normal mode, and I am sorry, but I missed "Rescue mode is not shown as red LED blink instead of green" (Probably remove the word "not"?)
It works. Inclusion was a little bit of a challenge, but at the end it came to 100%
Config parms work ok, the device is in sleeping mode and wakes up every [Wakeup-interval] seconds and it sends a Wakeup-notification. ZWavePlusInfo looks OK, the controller treats the device as a Reporting Sleeping Slave.
Just one question: in older firmware versions Sleeping Devices woke up every 4 minutes by design. It looks like now it (only) wakes up after the Wakeup-interval. Am I right? (No problem for me, now it works like I expect it to work) (Did I miss this too in the release notes?)
KR.
rishamee
p0lyg0n1
Re: New 2.1.5 beta
Post by p0lyg0n1 »
It was a bug ;-) We discussed it and seems we add a little further a special "flag" to wakeup every 4minutes if the user needed it without Wakeup-notification. The current version wakes up only after Wakeup-interval. You are right;)
Alex.
Rob
Re: New 2.1.5 beta
Post by Rob »
I tried to update to this 2.1.5 beta. The following issues have occured:
1. first I have received some CRC errors when burning the 2.1.5. bootloader.
2. I have repeated a few times and suddently it worked. (strange)
3. The compiler shows numerous "strncpyz prevented buffer overrun!" messages . I believe, this was not the case with 2.1.4.
4. After burning the bootloader, the device (which was previously included) did show-up anymore to the network and went dead. Is a re-inclusion after upgrading to 2.1.5. always needed? The sketch itself was not changed.
5. Afterwards I went back to 2.1.4. (removed the board from Arduino, switched back to the non-test repository, Installed 2.1.4.) but I'm unable to burn the 2.1.4. bootloader - error: "Error 0 There is no firmware "/Users/XXX/Library/Arduino15/packages/Z-Uno/hardware/zw8051/2.1.4/bootloaders/zuno_bootloader_AAAABBBB011501100001020F02*.bin" that is needed for your Z-Uno"
Thank you for your support
rishamee
Re: New 2.1.5 beta
Post by rishamee »
@Rob, you can burn the 2.1.4 bootloader from the test repository, and than go back to the main branch.
Re: New 2.1.5 beta
3. Can you show a sketch that lead tohia error, we check it
4. There is a change from one Z-Wave SDK to another one. This leads to erase of critical network data. Yes, n exclusion-inclusion is required.
5. 2.1.4 do not know about 2.1.5 and can not downgrade
Do downgrade right in the same test branch
