License <--- I give up
bncbnc83
Post by bncbnc83 »
I bought a licence
It says everything is okay when i install licence.
But the license is not installed
Please help
I tryed on Raskberry Pi and a ubuntu server same result
Role in Network
Node Id: 1
Home Id: 0xf3b54253
Primary Role: Yes
Primary Capability: Yes
SUC/SIS in network: 1 (SIS)
Hardware
Vendor: Z-Wave.Me
Vendors Product ID: 1024 / 1
Z-Wave Chip: ZW0500
Firmware
SDK Version: 6.71.01
Serial API Version: 05.26
Capabillities:
UUID: be93a614da9e7ef522a5d94925ab1049
Subvendor: 0x0115
Nodes limit: Unlimited
Capabillities: SlM
Software Information
Version number: v3.0.0
Compile-ID: fabbd8c917ba3564c3cee86f3baca2e04da1892f
Compile-Date: 2019-07-18 02:47:11 +0300
bncbnc83
Re: License <--- I give up
Post by bncbnc83 »
This is what the ui say
License key successfully verified
Capabilities successfully upgraded
This is what the logs say
[2019-10-21 14:09:13.849] [I] [zway] Adding job: Get or set Z-Wave.Me firmware capabilities
[2019-10-21 14:09:13.850] [D] [zway] SENDING (cb 0x02): ( 01 34 00 F5 5E D9 BC 37 17 90 4C 91 3B 41 82 5D 47 0C EB DC B1 0F 03 8F 3F 5F 3B 13 7C 49 69 20 ED 39 DB FD C4 E7 4E AE 69 99 58 3$
[2019-10-21 14:09:13.855] [D] [zway] RECEIVED ACK
[2019-10-21 14:09:13.870] [D] [zway] RECEIVED: ( 01 04 01 F5 CE C1 )
[2019-10-21 14:09:13.870] [D] [zway] SENT ACK
[2019-10-21 14:09:13.870] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2019-10-21 14:09:22.816] [D] [zway] RECEIVED: ( 01 25 00 F5 02 DA BE 93 A6 14 DA 9E 7E F5 22 A5 D9 49 25 AB 10 49 01 15 FF 05 00 00 00 00 00 00 00 00 00 00 00 00 89 )
[2019-10-21 14:09:22.816] [D] [zway] SENT ACK
[2019-10-21 14:09:22.816] [D] [zway] SETDATA controller.data.uuid = "be93a614da9e7ef522a5d94925ab1049"
[2019-10-21 14:09:22.816] [D] [zway] SETDATA controller.data.caps = byte[4]
[2019-10-21 14:09:22.816] [D] [zway]   ( 01 15 FF 05 )
[2019-10-21 14:09:22.816] [D] [zway] SETDATA controller.data.countDown = 0 (0x00000000)
[2019-10-21 14:09:22.816] [D] [zway] SETDATA controller.data.capsNonce = byte[4]
[2019-10-21 14:09:22.816] [D] [zway]   ( 00 00 00 00 )
[2019-10-21 14:09:22.817] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Done
[2019-10-21 14:09:22.817] [D] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): success
[2019-10-21 14:09:22.817] [I] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
[2019-10-21 14:09:27.471] [C] [i/o] Serial port has gone: (null)
[2019-10-21 14:09:27.471] [E] [zway] Device processing interrupted
[2019-10-21 14:09:27.471] [D] [zway] Worker thread exit point
[2019-10-21 14:09:27.480] [I] [core] Terminating Z-Wave binding
[2019-10-21 14:09:27.484] [D] [zway] Worker thread successfully finished
[2019-10-21 14:09:27.484] [I] [zway] Saving configuration data to config/zddx/f3b54253-DevicesData.xml
[2019-10-21 14:09:27.500] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
It was applied, all looks ok. Why do you think it is not uploaded?
bncbnc83
Post by bncbnc83 »
@PoltoS
ZMERestore (0xf3) is red ?
It is normal. Currenly another function is used to restore.
bncbnc83
Post by bncbnc83 »
@PoltoS
okay thank you
its also normal it says 0000001B in license ?
That was a bug. Fixed. This was your previous Demo license
bncbnc83
Post by bncbnc83 »
Thank you.
its working now :-)
bncbnc83
Post by bncbnc83 »
@PoltoS just one last question
If my Uzb1 break and i need a new Uzb1.
Do i need to buy a new licence or can i use the same
Yes ;( it is in the stick
