I have tried to install the node debugging (for programming a new module) but no success.
Tried different node version installations and different inspector versions - with different errors in result.
In most cases the inspector installation failed (as sample missing debugger, which cannot be installed).
And I have found the notice that inspector does not work with Node versions >8.x
As sample if inspector was starting he crashed after remote connection with
Visit http://127.0.0.1:8080/?port=8183 to start debugging.
/root/.nvm/versions/node/v6.1.0/lib/node_modules/node-inspector/lib/DebuggerClient.js:176
      done(err, JSON.parse(result.value));
TypeError: Cannot read property 'value' of undefined
I remember that it was working some time ago, have installed it in 2016 about
Is there a step-by-step instruction with the right steps, what to install? And - install as root or pi with sudo - is there any difference?
I'm sure that some users are using it today, so I hope that somebody can help
(BTW: the old posts here did not help, maybe they are outdated)
Configuraton should be: Z-Way and inspector at same machine and debugging with Chrome from Windows PC.
Thanks!
Michael
