Smarthome UI error
vinisz
Smarthome UI error
Post by vinisz »
On almost every change I do on a device (add a tag for example) and then press "Save" , I do get the error message as below:
The change is however saved, do look like cosmetic error but should not be there I think
enbemokel
Re: Smarthome UI error
Post by enbemokel »
+1
As a user, right? This was fixed https://github.com/Z-Wave-Me/zwave-smar ... 683a5590bc and will be part of next release
enbemokel
Post by enbemokel »
In my case it´s admin, and I noticed this more often, if I change 2 parameters at the same time.
But everything seems to work, so it´s just cosmetical.
Can you show the error in browser console log?
enbemokel
Post by enbemokel »
Hmm, tried but no success....everything is working now. Maybe the 3.0.3 fixed something.
I will post if I can reproduce it, maybe if I integrate a new device.
vinisz
Post by vinisz »
I have the problem as admin as well.
Error from browser console log is :
build.js?rel=1.10.1:8654 POST http://192.168.0.159:8083/ZAutomation/api/v1/instances 404 (Not Found)
Can we access it to reproduce? Have you checked the Google Assistant/Alexa checkboxes in device settings? Can you uncheck them?
vinisz
Post by vinisz »
Google Assistant/Alexa checkboxes ? Where should those be ? I do not see them, not in a single device.
enbemokel
Post by enbemokel »
I installed the Alexa App, then I can activate it in the elements view from dashboard.
