Windows release for v3.0.0 ?
Re: Windows release for v3.0.0 ?
Post by PoltoS » 16 Jan 2020 12:47
We have just made a beta for Z-Way v3.0.3: https://storage.z-wave.me/z-way-server/ ... 3-beta.msi
We are testing it to make a release this week. You can also test. Make sure to have a backup of the Z-Way folder before you install it
Currently no Google Home/Alexa and no WebSockets, but soon we add them too.
Ricard1
Post by Ricard1 » 16 Jan 2020 13:55
PoltoS wrote:
16 Jan 2020 12:47
Finally PoltoS ;) Many thanks, I will test it asap! :)
Kind regards,
Ricard
Ricard1
Post by Ricard1 » 17 Jan 2020 12:29
PoltoS wrote:
16 Jan 2020 12:47
Hi again,
I tested the Win release yesterday and installation worked fine, however there is so many user actions that fails, did you really test this Windows build? I mean normal use, clicking menu selections to see basic functionality working? Yes I did set COM port and got controller access, so far ok.
I believe you have at least one Windows PC around to experience the errors, errors I recognize since last previous 2.x.x versions ;)
Best regards
Post by PoltoS » 18 Jan 2020 11:54
Of course there are still errors in it, it is a beta ;)
Skins, icons and S2 don't work for now. We are working on this.
We would appreciate if you can share your findings do we can fix all we find. Z-Way is big, so full test takes time and we decided to get feedback from the community earlier
Post by PoltoS » 23 Jan 2020 14:51
Hello!
New Z-Way version for Windows is here. This is a pre-release beta. One single missing point is remote access - we are doing it.
https://razberry.z-wave.me/z-way-server ... 4-beta.msi
What what fixed:
- Fixed Security S2 (was not working)
- Fixed Skins and Icons download
- Fixed configuration file permissions
Your input is appreciated!
Ricard1
Post by Ricard1 » 23 Jan 2020 15:31
Hi Polto
Thanks, will test an let you know my results :)
Best regards,
Ricard
Ricard1
Post by Ricard1 » 09 Feb 2020 22:14
PoltoS wrote:
23 Jan 2020 14:51
Hello!
At present I run Domoticz on the Win 7 PC I do the tests on, I stop the Domoticz service and starts Z-Way and so far so good.
However, as I did not use Z-Way much I am wondering how to find the existing Nodes registered on the Controller, from Domoticz? I only see the ZWay.me UZB Controller itself as Device 1 but not the Nodes already paired...
Home-ID is fine, and I have the security key from Domoticz but I cannot find were to insert it, if needed/possible?
Also, looking at Controller "Wireless activity" it says Device is dead (or similar).
At the Network-->Controller I tried to use the Controller Backup function but it results in "Not authorized" (or similar)
Thanks!
Post by PoltoS » 15 Feb 2020 16:58
In expert UI you should see all devices, but no interview. For unsecure devices.you can just force interview. For secure you should first insert the security key. It is 16 bytes
