DHT22 sensor with decimals
veuchez
Post by veuchez »
Hi everyone,
i can't figure out how to get decimals on the temperature and humidity readings from the DHT22 sensor.
Can anyone help me please?
Thank you!
veuchez
Re: DHT22 sensor with decimals
Post by veuchez »
I think I have solved this, now I do some tests.
// add library
#include "ZUNO_DHT.h"
// pin connection
#define DHTPIN 9  // first sensor
DHT dht(DHTPIN, DHT22);
int temperatura; // here we will store the temperature
int umidita; // here we will store the humidity
// set up channel
ZUNO_SETUP_CHANNELS(
   ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
                          SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS,
                          getterTemp),
   ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_RELATIVE_HUMIDITY,
                          SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE,
                          getterUmid)
void setup() {
    Serial.begin();
    Serial.println("start");
void loop() {
    // obtaining readings from the sensor DHT22
    float temp = dht.readTemperature();
    // make scaled word value for report
    temperatura=int(temp*100);
    float umid = dht.readHumidity();
    umidita=int(umid*100);
    // send data to channel
    zunoSendReport(1);
    zunoSendReport(2);
    // send every 20 second
    delay(20000);
word getterTemp() {
    return temperatura;
word getterUmid() {
    return umidita;
