Device status "date" in advanced via API
vinisz
Post by vinisz »
Wondering how to retrieve the "date" field via the ZwaveApi.
I have access to the API, no problem, but can't figure out which field containts the "date" field or what it represents.
Schermafbeelding 2020-10-16 154329.jpg (35.86 KiB) Viewed 4404 times
Schermafbeelding 2020-10-16 154422.jpg (57.78 KiB) Viewed 4404 times
gsaw
Re: Device status "date" in advanced via API
Post by gsaw »
I guess you want the field updateTime. It is in Unix-Time format
2020-10-16 18_40_39-192.168.178.168_8083_ZWaveAPI_Data.png (30.85 KiB) Viewed 4398 times
vinisz
Post by vinisz »
Thanks,
And which “updatedtime” should I use then, cause I see one for every “setting”
Is the one you’re pointing out here the correct one ?
gsaw
Post by gsaw »
vinisz wrote:
17 Oct 2020 09:30
Thanks,
Each device have a global attribute updateTime. I think, it is that waht you need. But i'm not sure. If you want to be sure, you could try to figure it out in source code of Z-Way.
https://github.com/Z-Wave-Me/zwave-smarthome
2020-10-17 10_26_19-192.168.178.168_8083_ZWaveAPI_Data.png (179.48 KiB) Viewed 4383 times
vinisz
Post by vinisz »
Well, for sure it is not that one.
that seems to be the time that device was added or something.
I'm thinking more about the "last received time" now.
I would assume you are searching for lastSend and lastReceived fields and their updateTime propery. Those are used in this part of the UI
