SmartHome UI - Notification - problem troubleshooting
kosinus33
Post by kosinus33 »
I have several problems with the timer and so on. One timer ist working the other one does't work. I receive some E-Mail messages. How can I figure out, where the problems are come from? An ID in the error message would be nice. An ID for an I -Then or timer, also.
The following notification appeared in Your Z-Way System:
Error during perform command execution: Error: Invalid operation
Best Regards
Z-Wave.Me
NotificationChannelEmail error
Best Regards
Z-Wave.Me
Can't register duplicate module instance: 35
Best Regards
Z-Wave.Me
Can not fetch weather information.
Best Regards
Z-Wave.Me
Any ideas?
br
Re: SmartHome UI - Notification - problem troubleshooting
Looks like your config somehow contains two times app with id 35. You should check the config.json in automation/storage/ folder (with Z-Way turned off) to fix it. Use JS beautifier or JS editor to easier navigate it.
kosinus33
Post by kosinus33 »
I excluded the device an I tried to include the device #35 again, servers times. The interview is not completed.
enbemokel
Post by enbemokel »
"IP-ADDRESS":8083/JS/Run/zway.devices[X].AssociatonGroupInformation.interviewDone=true
may help you, otherwise search in the forum for "interviewDone"
kosinus33
Post by kosinus33 »
Hi, sorry for the late response. I had a lot of errors. I deleted all rules and sences, today. The error is gone without your workaround. I hav no idea why. Thank you.
kosinus33
Post by kosinus33 »
I think i found the problem. It seems the device was inventoried twice. I saw this at the expert GUI. This was not visible in the normal GUI. I will add new device in the Expert GUI only next time.
