uzb firmware upgrade issue
goul
Post by goul »
Can't update from 05.37 to 5.39 using z-way expert ui.
Attached device info, no changes loading UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_27_04000001_ZME_05_27_04000001.bin
from graph
{"id":"1127","baseid":"","enabled":"enabled","type":"firmware","file":"bin","vendorID":"277","bootloaderCRC":"40196","appVersionMajor":"5","appVersionMinor":"39","targetBootloaderCRC":null,"targetAppVersionMajor":"5","targetAppVersionMinor":"39","fileURL":"UPD_FIRMWARE_UZB_STATIC_2ch_ZME_05_27_04000001_ZME_05_27_04000001.bin","released":"2020-07-02","comment":"Switch to firmware for EU\/US\/RU\/IN\/CN\/ANZ\/BR","position":"1","version":"5.39"}
Senza titolo-3.png (10.76 KiB) Viewed 9226 times
Re: uzb firmware upgrade issue
The file is 39->39 (to switch channels). Looks like you are using a wrong file
Enter token all and use the UI to do it. No need to download files.
goul
Post by goul »
PoltoS wrote:
17 Nov 2020 04:43
Thanks.
