Z-Way App for Android
Re: Z-Way App for Android
Wanted to try what you proposed, but (click 5 times on OR word between Scan QR) where can I find the "OR" word?
Click on + sign in the list of hubs. If you never get's there, press Cancel button on load.
I hit the + and then? No OR
- Screenshot_20210309-202424.png (44.3 KiB) Viewed 11604 times
What do you see once you press it? There should be two buttons and OR between
I see exactly this screen.
Sorry, in last versions OR was replaced by a dash
Because now more buttons appear here
Finally works since v3.1.3 and only one admin. It's ok for me now.
Perfect! Would be glad if you change your review in Google Play
Same happened with me after updating the Android version. Today I got the Android 11 update on my ROG Phone and since then the app is showing "Unfortunately App Has Stopped". How to fix this?Dempsey wrote: ↑20 Feb 2021 15:37Something is similar happened to me, I've been using Z-way App on my Note 9 for a while now. It was running just smooth on Android Oreo however today I received the Android Pie update and now whenever I am trying to open the yo whatsapp App it is only displaying a white blank screen at the startup. Please help!!Franz Winchester wrote: ↑06 Feb 2021 18:33Hello,
I tried again and from this moment on the app does not work any more. Reinstall, update manually to v3.1.2...all a mess.
The app starts, the I scan the QR-code an it starts to connect. After some time it's getting stuck and you can only acceess the "to hub" and try again or access login data, but with no success. I will try to send you a video, but it might be too large, because the process takes several minutes.
Regards
Thomas
Top
