Z-Wave v3.1.3 Release
Franz Winchester
Re: Z-Wave v3.1.3 Release
Post by Franz Winchester »
When will it finally be fixed? :evil:
We were not able to find issues with ordering on the dashboard.
Please make sure to clear cache - this issue was in v3.1.2 and may be the browser still partially uses old files from the cache.
If this does not help, please assist us in providing access to your system to check the issue.
Meanwhile we have prepared v3.1.4 with few other fixes and if all tests will be ok, we release it soon. Those are really minor changes, especially in Security and Heating apps.
enbemokel
Post by enbemokel »
I have round about 55 devices at dashboard, maybe thats the problem.
Could you please check 3.1.4 and if not ok, please provide us access to such a huge dashboard, so we check see the issue
Franz Winchester
I have 96 on the dashboard. Until v3.1.1 no problem.
And definetly not a browswer cache problem.
How should I grant access for you?
Btw, I got the app running, but only after I deleted the second admin and access the system with the admin user. But there also items on the dashboard and in the rooms are scrambled after each reboot.
enbemokel
Post by enbemokel »
Hi Polto,
I assume that you do have a test system with devices and just add more of them to the Dashboard.
Don´t think that it is huge, it´s the easiest (and fastest) way to control different devices without changing to rooms all the time.
enbemokel
Post by enbemokel »
btw. this is one of the most annoying bugs i ever saw....as it hits me every time i log in....
Franz Winchester
100% agree. What about the solution?
@Franz Winchester or @enbemokel, could you please provide us access so we check it. We don't experience this anymore. If one of you can allow us get access and check your current and the latest system, we will fix it asap.
The dashboard issue should be finally fixed in v3.1.4 - it is released and online.
