Multi Wallmount Switch
Michael S
Post by Michael S »
At the moment I am building a new private SPA.
For this I am planning to have a full Smart Setup with z-Wave.
Requirements:
1 central wall mount control to manage all the Light, ideally the Roller-Shutter as well. This should be a modern look, e.g. Glas
Ideally I should be able to configure 2-4 different Scenes of all 5 Lights with one Button pressed, or switch everything off in one step.
Perfect it would be, to even be able to control the Radiator (Devolo Thermostat)
Light Configuration:
3 different Lights, white, min: individual on/off, max: dim function
2 LED RGBW: individual dim and color adjustment
My Ideas as well is to have one central 12/24V Power supply, feeding all 12/24V light units. I am clear that the total power need to be the total sum of all Lights connected and witched on.
I have a very central point to have a very short wiring to all different Lights.
Is there anyone, could tell me, what would be the best components to be used for that Config?
Michael
enbemokel
Re: Multi Wallmount Switch
Post by enbemokel »
KNX :-)
If everything is central, this would be my choice.....
Michael S
Post by Michael S »
...it KNX working with a existing Z-Way based on Raspberry or is that a complete controler?
enbemokel
Post by enbemokel »
HI, in general it has nothing to do with zwave, even there are existimg interfaces.
But, I want to say that I wouldn´t use zwave if I have a central point, where i can control all devices.
Then there is no need to use zwave from my point of view.
