THANKS!
Managed to install 3.2.1 with the help of command
sudo apt --fix-broken install (some Mosquito disturbing)
My complaints regarding 3.2.0 and "Devices that don't need to be displayed in HomeKit" is heard and is now fixed
BUT in order to use it I have to remove the bridge in the Home App and RENAME the "Name as it appears in iOS devices" to a new every time. Otherwise the Home App "Add new device" does not find Z-way when searching. (can't replicate this behavior )
Also removed and reinstalled the Apple HomeKit Gate (please also note new Apple HomeKit Pin), restarted the RPi4B with the command SUDO REBOOT.
But more Happy now!
Great!
Thanks to PoltoS & Co
3.2.1 and devices that don't need to be displayed in HomeKit
Re: 3.2.1 and devices that don't need to be displayed in HomeKit
Where did you get 3.2.1? I don't see it in what I think is the official repo: https://repo.z-wave.me/z-way/raspbian/p ... ay-server/
RaZberry ZW0500 1024/2 SDK: 6.82.01 API: 05.39
Z-Way version v4.1.0
Not yet a good idea to install the test version of 3.2.1
Agreed. FWIW, I think in a way 3.2.0 is also a test version, there hasn't been made an official announcement yet as far as I can see. But that's what we're here for, right?
@xurg It is here https://storage.z-wave.me/z-way-server/
Please check all critical issues with v3.2.0 are gone. We are collecting early adopters feedback before doing a final release.
Ok PoltoS: Here is my install sequence!
pi@raspberrypi3Bplus:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi3Bplus:~ $ wget https://storage.z-wave.me/z-way-server/ ... _armhf.deb
--2021-09-17 22:05:02-- https://storage.z-wave.me/z-way-server/ ... _armhf.deb
Resolving storage.z-wave.me (storage.z-wave.me)... 185.25.224.210
Connecting to storage.z-wave.me (storage.z-wave.me)|185.25.224.210|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19634752 (19M) [application/x-debian-package]
Saving to: ‘z-way-3.2.1_armhf.deb.5’
z-way-3.2.1_armhf.d 100%[===================>] 18.72M 2.21MB/s in 12s
2021-09-17 22:05:14 (1.57 MB/s) - ‘z-way-3.2.1_armhf.deb.5’ saved [19634752/19634752]
pi@raspberrypi3Bplus:~ $ sudo dpkg -i z-way-3.2.1_armhf.deb
(Reading database ... 42519 files and directories currently installed.)
Preparing to unpack z-way-3.2.1_armhf.deb ...
Stopping z-way-server: done.
Unpacking z-way-server (3.2.1) over (3.2.1) ...
dpkg: dependency problems prevent configuration of z-way-server:
z-way-server depends on libmosquitto1 (>= 2.0.10); however:
Version of libmosquitto1:armhf on system is 1.5.7-1+deb10u1.
dpkg: error processing package z-way-server (--install):
dependency problems - leaving unconfigured
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
Errors were encountered while processing:
z-way-server
pi@raspberrypi3Bplus:~ $ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following additional packages will be installed:
libmosquitto1
The following packages will be upgraded:
libmosquitto1
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 82.6 kB of archives.
After this operation, 49.2 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://repo.mosquitto.org/debian buster/main armhf libmosquitto1 armhf 2.0.12-0mosquitto1~buster1 [82.6 kB]
Fetched 82.6 kB in 0s (312 kB/s)
Reading changelogs... Done
Preparing to unpack .../libmosquitto1_2.0.12-0mosquitto1~buster1_armhf.deb ...
Unpacking libmosquitto1:armhf (2.0.12-0mosquitto1~buster1) over (1.5.7-1+deb10u1) ...
Setting up libmosquitto1:armhf (2.0.12-0mosquitto1~buster1) ...
Setting up z-way-server (3.2.1) ...
Raspberry Pi 3B/3B+ Detected. Disabling Bluetooth
Opened config/zddx/c7cdb7c3-DevicesData.xml
Starting z-way-server: done.
Processing triggers for libc-bin (2.28-10+rpt2+rpi1) ...
pi@raspberrypi3Bplus:~ $ sudo reboot
VERSION_ID="10"
ID=raspbian
ID_LIKE=debian
z-way-server
libmosquitto1
libmosquitto1
Did some testing with on one Fibaro Door/win.
Test Apple HomeKit Gate 2.2.1 in server 3.2.1
iOS 15.0
iPhone 8
Apps:
HomekitGate 073-80-946 RaZberry5
Uppträder som Z-Way 5 (I added the 5)
-Battery Polling
-Dear Expert User
-Cloud Backup Instructions
-Sensor General purpose (2)
FibaroTemp1
-FibaroAlmH2
FibaroWin1
-FibaroTamp
-Fibaro Alarm System (2)
-Fibaro Battery (2)
Show FibaroTamp, save, no tags -> shows up in Home
Remove bridge in HomeKit, keep name RaZberry5 -> Add bridge in Home
Icon shows up with correct name RaZberry5, added devices in rooms
Bridge shown as Z-Way
Change name on FibaroWin1 to FibaroWin in Apps:Apple HomeKit Gate
Save in Apps:Apple HomeKit Gate
Name changed in Home
Remove (dont dispaly in HomeKit) FibaroTamp in Apps:Apple HomeKit Gate
in Home: Icon FibaroTamp indicates with House(Home) symbol and Not supported
sudo reboot
no change
Removed (dont dispaly in HomeKit) FibaroTamp still shows up in Home
NO devices works anymore, 3 devices No answer
sudo reboot
Apps:Apple HomeKit Gate, clicked Activate/Deactivate (pause), Clicked run (run)
2 devices works correctly, removed (dont dispaly in HomeKit) FibaroTamp still shows up in Home
iOS 15.0
iPhone 8
Apps:
-Battery Polling
-Dear Expert User
FibaroTemp1
-FibaroAlmH2
FibaroWin1
-FibaroTamp
-Fibaro Battery (2)
sudo reboot
no change
sudo reboot
Just about every accessory doesn’t require another app other than for initial setup purposes. After setup, you can delete the manufacturer’s app. Their app sometimes has more features included than the regular Home app, but it isn’t a required download to keep after the setup process.
Not used any manufacturer app at all! Only Z-Way!
Good night and good bye !
