MQTT Client
MQTT Client
I'm a little bit confused. I activate MQTTClient and this part working fine. But there is a battery device in my list only shows battery polling... All other Battery devices will show with device product name and device number... Is there a way to rename battery devices to adequate name like MyDeviceBat or anything else?
Greatings from the noob
Re: MQTT Client
In there UI battery widgets are ignored. But you can use the API: /JS/Run/controller.devices.get("ZWayVDev_zway_NN-0-128").set("metrics:title", "new name")
Re: MQTT Client
Thanks for response. I give a try.
Battery Polling is an app.
