Fibaro Devices Firmware FGS-223
J.nissen
Post by J.nissen »
Hello how can I update the Firmware for my fibari Divice
FGS-223 ?
Is there any Download Point ?
Greetings from germany
Jörg
vinisz
Re: Fibaro Devices Firmware FGS-223
Post by vinisz »
you can't, only if you have a fibaro controller
J.nissen
Post by J.nissen »
Can i Add Fibaro hcl as secondary Controller ?
Jörg
Yes, you can
J.nissen
Post by J.nissen »
I have added an HCL 2 Lite as secondary Controler.
Then I started Soft Configuration...
But the Soft Configuration doesn´t work.
It find no End ...
2021-12-17 07_08_41-Home Center Lite.png (145.37 KiB) Viewed 5192 times
2021-12-17 07_13_58-Z-Wave Expert UI.png (85.47 KiB) Viewed 5192 times
Has you any Idea ?
Logfile
see Devie 25,
[2021-12-17 07:36:32.576] [D] [zway] SETDATA devices.25.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2021-12-17 07:36:32.576] [D] [zway] SETDATA devices.25.data.lastNonceGet = 13986781 (0x00d56bdd)
[2021-12-17 07:36:32.576] [zway] Waiting for job reply: Nonce Get from node 25
[2021-12-17 07:36:34.087] [D] [zway] Job 0x3b: deleted from queue
[2021-12-17 07:36:34.378] [D] [zway] Job 0x13: deleted from queue
[2021-12-17 07:36:34.731] [W] [zway] Reply not received before timeout for job (Nonce Get to node 25)
[2021-12-17 07:36:43.025] [zway] Node 25:0 CC Security: sending Nonce Get
[2021-12-17 07:36:43.025] [D] [zway] SETDATA devices.25.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2021-12-17 07:36:43.025] [zway] Adding job: Nonce Get to node 25
[2021-12-17 07:36:43.026] [D] [zway] SETDATA devices.25.data.lastNonceGet = 13987781 (0x00d56fc5)
[2021-12-17 07:36:43.036] [D] [zway] SENDING (cb 0x22): ( 01 09 00 13 19 02 98 40 25 22 21 )
[2021-12-17 07:36:43.038] [D] [zway] RECEIVED ACK
[2021-12-17 07:36:43.042] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2021-12-17 07:36:43.042] [D] [zway] SENT ACK
[2021-12-17 07:36:43.042] [D] [zway] Delivered to Z-Wave stack
[2021-12-17 07:36:43.061] [D] [zway] RECEIVED: ( 01 18 00 13 22 00 00 02 00 CA 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 1F )
[2021-12-17 07:36:43.061] [D] [zway] SENT ACK
[2021-12-17 07:36:43.061] [zway] Job 0x13 (Nonce Get to node 25): Delivered
[2021-12-17 07:36:43.062] [D] [zway] SendData Response with callback 0x22 received: received by recipient
[2021-12-17 07:36:43.062] [D] [zway] SETDATA devices.25.data.lastSendInternal = **********
[2021-12-17 07:36:43.062] [D] [zway] SETDATA devices.25.data.lastSend = 13987784 (0x00d56fc8)
[2021-12-17 07:36:43.062] [D] [zway] Job 0x13 (Nonce Get to node 25): success
[2021-12-17 07:36:43.062] [D] [zway] SETDATA devices.25.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2021-12-17 07:36:43.062] [D] [zway] SETDATA devices.25.data.lastNonceGet = 13987784 (0x00d56fc8)
[2021-12-17 07:36:43.062] [zway] Waiting for job reply: Nonce Get from node 25
[2021-12-17 07:36:43.408] [zway] Adding job: Get background noise level
[2021-12-17 07:36:43.417] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2021-12-17 07:36:43.418] [D] [zway] RECEIVED ACK
[2021-12-17 07:36:43.419] [D] [zway] RECEIVED: ( 01 05 01 3B AD A5 C8 )
[2021-12-17 07:36:43.419] [D] [zway] SENT ACK
[2021-12-17 07:36:43.420] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 173 (0x000000ad)
[2021-12-17 07:36:43.420] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2021-12-17 07:36:43.420] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2021-12-17 07:36:43.420] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -91 dBm, Ch#2: -91 dBm, Ch#3: not available
[2021-12-17 07:36:43.420] [D] [zway] Job 0x3b (Get background noise level): success
[2021-12-17 07:36:43.420] [zway] Removing job: Get background noise level
[2021-12-17 07:36:44.878] [D] [zway] Job 0x13: deleted from queue
[2021-12-17 07:36:45.018] [core] [Astronomy] Calculate
[2021-12-17 07:36:45.074] [core] HK: updated Astronomy_29_altitude
[2021-12-17 07:36:45.081] [I] [core] Notification: device-info (device-status): {"dev":"Sonnenstand","l":"-8.36 °","location":0}
[2021-12-17 07:36:45.103] [I] [core] HK: updated Astronomy_29_azimuth
[2021-12-17 07:36:45.107] [I] [core] Notification: device-info (device-status): {"dev":"Sonnenazimut","l":"119.01 °","location":0}
[2021-12-17 07:36:45.153] [I] [core] [BaseModule-30] Set lastLevel to -8.36 for Astronomy_29_altitude (was -8.49)
[2021-12-17 07:36:45.157] [I] [core] [BaseModule-30] Set lastLevel to 119.01 for Astronomy_29_azimuth (was 118.81)
[2021-12-17 07:36:45.236] [W] [zway] Reply not received before timeout for job (Nonce Get to node 25)
(END)
Jörg
For some reason, Node 25 is not answering security. Does it support it? Was it included with security?
