Windows Z-Way Service (ZWaySvc) could not be started
Hanau4
Post by Hanau4 »
Hi community,
I´m Norbert - from Germany.
I use UZB and Z-Way Software successfully on different Windows PC´s.
Now I gut 2 new mini PC´s one with Win10 pro, the other with Win 11 pro.
When installing z-way-server-windows-v3.2.1 and others,
installation almost runs through ...
until the Services are going to be started ...
after 5 sec. the installations causes the above error.
Options are "retry" and "abort"
I changed the Service-Start timeout in the registry
checked the user permissions
asked Dr. Google ...
and I have no clue left ';)
maybe you had the same issue and solved it already -
or any ideas are welcome.
thanks and kind regards
Norbert
Re: Windows Z-Way Service (ZWaySvc) could not be started
Hello!
Looks like the Z-Way service fails to start. There should be a log in the c:\program files\z-way server folder. Please open it and show the error.
alexis92
Post by alexis92 »
Which of the mini-PCs are you facing the error on? The one with Win10 or Win11?
Hanau4
Post by Hanau4 »
Good morning,
thanks PoltoS and Alexis92 for your comments and questions.
It happened on both mini PC´s ... Win10 and Win11
Searching for the log file, I found the file: z-way-svc
When executing the file, a more specific error came up: VCruntime140.dll missing
I downloaded (from Microsoft) and reinstalled the VC Library - no success.
I noted that z-way installed in programs(x86) directory.
Downloaded the x86 Version of the VC Library, installed it
and now it works like usual ;)
Thanks again
best regards
Norbert
