Heating Control What is What ?
J.nissen
Post by J.nissen »
can someone explain me the heating control ?
What / what for is frost protection temperature ?
When is this setting used
What is energy saving temperature ?
When is this setting used ?
What is comfort temperature ?
Is the setting correct here? I would like to have the heating at 25 degrees during the day.
My thermostat is a
Heizung Büro.png (21.49 KiB) Viewed 2343 times
Greetings from germany
Jörg
Re: Heating Control What is What ?
Frost protection is the temperature that conserves your house at a minimal temperature when you are away (not to let water in tubes frost). Feel it like "heating off" with a remark that it is not allowed to turn it off completelly not to damage tubes. Typically it is 6-10°C.
Comfort temperature is the temperature you are comfortable with. Use it when you are at home. Usually 22°C
Energy saving is a reduced temperature that saves energy but is not too low to make heating to Comfort not to energy consuming. Typically 12-16°C.
J.nissen
Post by J.nissen »
Hello Polto,
Thank you for your explanation. However, I must have asked imprecisely. :-)
When are the tempratures used by Zway ?
The values I set ( 7:00 am to 10:00 am , 25 degrees ) are ignored.
Do you have any idea what I am doing wrong here ?
Jörg
