FGS-223 no Power Events
Re: FGS-223 no Power Events
What is the difference in device types? Does the first device have events?
The one with the events (the one that is working) is a routing multilevel switch. (Fibaro FGD-212)
The other one (not working) is a binary power switch. (Fibaro FGS-223)
I have run into a similar problem. Was there a conclusion?
As a workaround I set Periodic reports to 300. Then the FGS-223 reported power every fifth minute but after a while it stops.
If I switch off/on it recovers but it will stop reporting power after 30-40 reports.
I use the switch to moinitor the Automower status where I rely on the power consumption being reported.
The FGS-223 does not stop reporting, it is zway stap stops reporting/storing...
I still have issues with reporting, data is not saved for longer periods but I gave up about it, it should have been solved but it is not..
Thanks for the response vinisz.
Sorry I did not mention that I'm running Domoticz but I was pretty sure this was a FGS-223 issue so that is why put the post here. Are you saying that the problem is on the controller side? Has that been confirmed? Previously I used the Fibaro wall plug for the same purpose an there was no issue with the power reports.
In file:
/opt/z-way-server/automation/modules/InbandNotifications/index.js
remove line:
The problem is fixed in the release version 4.0.
remove line:
if (devProbeType.indexOf('meterElectric_') !== -1) return;
ok thanks, I'll just wait for version 4 to be released, I guess it will be soon by now ?
