V4.0.0
markchang
V4.0.0
Post by markchang »
Since 1 nov i see in firme upgrade v4.0.0 versión but after click on update, i continue to see 3.2.3
After this, ive lost link with HomeKit (HomeKit had accesorios but they dont work toge athée with wow avé) and after erase them in HomeKit, firstly it diesen recognice all (only smoke sensors) and now, it doesnt rencogniez 4kt code.
I have talked about this in other topic but i think that v4.0.0 attempt and HomePod inclusión with v16 could be the reason.
What d’où you think?
J
pdekuewit
Re: V4.0.0
Post by pdekuewit »
I tried to update as well and the message below remains unchanged for a very long time ( > 16 hours). After that I restarted the system and everything was as it was before. Trying again to upgrade to 4.0.0 gave exactly the same result.
sw update.jpg (30.54 KiB) Viewed 12951 times
Re: V4.0.0
It is available as a .deb package, but has not yet been added to the repository. It will be added next week so you will be able to upgrade.
markchang
Re: V4.0.0
Post by markchang »
Ok, thank you
kosinus33
Re: V4.0.0
Post by kosinus33 »
Thank you for contacting us with this question, yes, we are aware of this problem and we will fix it soon, but you can solve the problem yourself and connect via SSH faster and run the command:
cd /tmp && wget https://storage.z-wave.me/z-way-server/ ... _armhf.deb && sudo dpkg -i z-way-4.0.0-lws16_armhf.deb
Re: V4.0.0
It is out now
vinisz
Re: V4.0.0
Post by vinisz »
I just upgraded but now all fibaro multisensors (FGMS-001) are only showing luminsense and temperature, motion is gone...
In expert interface it still looks good... how can I get it back ?
ibjr
Re: V4.0.0
Post by ibjr »
I have exactly the same problem: I have 3 of these FGMS-001 sensors, all 3 are missing the motion sensor after upgrading to 4.0.0
vinisz
Re: V4.0.0
Post by vinisz »
Yep, I have it with all of them which is quite a problem, all motion based automation stopped working
Re: V4.0.0
Opps. Thank you for this info. I'll pass it on to our testers.
