Unplugged device still reporting data
harre
Post by harre »
I have one device that is unplugged, but it still shows up as active and its time get updated.
Node 66 has been unplugged atleast 12hrs
See attached image and logs at:
https://www.dropbox.com/s/90m3ibml76ftc ... 2Clog?dl=0
Screenshot 2022-12-09 at 13-42-50 Z-Wave Expert UI.png (11.3 KiB) Viewed 4729 times
Re: Unplugged device still reporting data
hm.. The log tells that the last delivered command to the devices was at 2022-12-09 13:33:37.51. So, it is not unplugged!
harre
Post by harre »
Node 65, 66 and 71 are from same manufacturer and they had some issues initially to get included with S2. It took a few retries with include and exclusion before they got working.
They are sometimes losing contact and takes a few retries to toggle the switch.
Is there anything else you can find in the log?
Node 61 has often S2 messages getting not received.
harre
Post by harre »
My bad. Node 66 was indeed plugged in. It is the 65 node i have unplugged. But that device still haven't went to faulted.
harre
Post by harre »
PoltoS wrote:
11 Dec 2022 04:00
Did you see my reply in this thread?
