Just an FYI that the new Zooz Zen77 800 paired Long Range will not complete interview.
Much like the Inovelli Red 2in1 it never completes the Indicator interview.
Zooz Zen77 800 Will Not Complete Interview
Re: Zooz Zen77 800 Will Not Complete Interview
Z-Wave.me would need to see the log file. Saying something doesn't work isn't going to get fixed without them actually seeing what is failing.
Fair point!
Here is a Force Paring with clean log file.
- z-way-server - Zooz Zen77 800.zip
- (98.8 KiB) Downloaded 733 times
Sometimes the device does not answer on packets (this is what happened few times during the interview in the log). The new v4.1.2 (newer that the one you are using) is better in persisting. Should work.
No change log for 4.1.2?
https://storage.z-wave.me/z-way-server/
Not here either:
https://z-wave.me/z-way/version-history/
I can confirm that the interview completed as expected on 4.1.2.
https://github.com/Z-Wave-Me/home-autom ... ANGELOG.mdNo change log for 4.1.2?
Installed it a few days ago. It works, but it needs much more cpu (process zway/core).
Has any body the same experience?
Thanks! I didn't think to look there. I was already running a beta of 4.1.2, so don't see any real difference in CPU usage on my rpi versus that.piet66 wrote: ↑12 Dec 2023 12:15https://github.com/Z-Wave-Me/home-autom ... ANGELOG.mdNo change log for 4.1.2?
