Hi, earlier I have been able to update the internal clock in my Z-Uno (ver 2), via TimeParameter command class.
For som unknown reason I changed frequence to RU and lost contact with Z-Uno.
So I removed it via "Failed node" before I noticed the frequence fault.
Then I excluded Z-Uno it from network and included it again.
Now in expert UI there is no TimeParameter command class showing.
It's 3.0.12 running.
What have I done wrong?
TimeParameter command class don't show up in ExpertUI
Re: TimeParameter command class don't show up in ExpertUI
Sure it us not in rescue mode? Is your sketch still running?
Yes it is running.
How do I know if it's in rescue mode?
If rescue mode changes to normal state after reset, it is in normal state.
Hi again.
I have excluded and included again, no difference, still no TimeParameter command class.
What is wrong?
What is wrong?
Is your logic running? If so, the sketch is correct. Otherwise, it is in reset mode. Also, make sure the loaded sketch contains the Time Parameter CC.
It might be that you included tho Z-Uno with the correct sketch and then loaded another one without, but Z-Uno have not applied those changes until re-inclusion (this is by design). So you have not noticed it before you have excluded and included back.
