Trigger SerialAPI Soft reset
Spacerat
Post by Spacerat »
After a few days my Z-Wave network seems to freeze and does not respond anymore. Then I log into the expert UI and trigger a Serial API soft reset on the controler page (then the network is fine again).
Now i want to do an automation (within my home assistant server) to check if Z-Way is still working as expected, else trigger soft reset.
I found out that this maybe the right call:
http://<raspberrypi>:8083/JS/Run/zway.SerialAPISoftReset()
But I get a "Not logged in" message. How do i pass Username & PW in this call?
lanbrown
Re: Trigger SerialAPI Soft reset
Post by lanbrown »
Before heading down that route, are you running the latest firmware for the Razberry board? On the Razberry 7 line, there have been issues related to bugs from Silicon Labs in the SDK. The latest release seems to have resolved many of the issues for most people.
Spacerat
Post by Spacerat »
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1025 / 257
Z-Wave Chip: ZW0700
Firmware
SDK Version: 7.20.00
Serial API Version: 07.40
Z-Way: 4.1.3
As far as i know is this the latest version of the software and controller.
Spacerat
Post by Spacerat »
Is this the right approach?
POST request to http://<raspberrypi IP>:8083/JS/Run/zway.SerialAPISoftReset()
Header: ZWAYSession = <permanent token> (created on user admin page)
lanbrown
Post by lanbrown »
Spacerat wrote:
25 Jul 2024 16:11
It is not:
SDK Version: 7.21.00
Serial API Version: 07.42
That update on the Razberry fixed issues for many people. The soft reset was and is a workaround for the bugs in the SDK from Silicon Labs. I would update the firmware on the Razberry and then reassess the issues you have.
Spacerat
Post by Spacerat »
OK, how can i get the update? If i try i get this:
lanbrown
Post by lanbrown »
Check the other thread topic that was right below or above your thread:
https://forum.z-wave.me/viewtopic.php?f=3419&t=36079
The upgrade was fixed. Please retry
