Fiabro door/window sensor
You can try out v1.4.1-rc1
You can try out v1.4.1-rc1 instead. It fixes this problem.
You need to run same install script, but att after /install -> /install/v1.4.1-rc1 (or v1.3.1 if you want to downgreade)
dthavot
problem not solved for me
Post by dthavot »
hi, i have updated my raz to 1.4.1-rc1, excluded , reseted, re-included my fibaro door/sensor, when i open the circuit the status pass from idle to triggered but the map icon stay blocked in green color and dont change. have i configured something wrong ? i dont know could you help me with my device config xml file:
thanks by advance.
Silversquasher
problem not solved for me too
Post by Silversquasher »
Hi, I have the same problem with the same new release 1.4.1-rc1.
Best Regards
P.S. : When can we have the Automation tab integrated in Z-Way UI like Z-Cloud for several years ? Is there a roadmap ?
The icon is not changed due
The icon is not changed due to internals of the blue UI. We are working on the new UI with automation.
dthavot
Opera is now supported
Post by dthavot »
about UI in browsers, just for info OPERA NEXT 18 is now supported by UI. all looks like working like a charm.
sjnelle
We will ask Fibaro to change
Post by sjnelle »
We will ask Fibaro to change this in future, but as a workaround one can bind to Basic Set and update SensorBinary.data[NN].level
How will I do this the lates version will also not work 1.4.1-rc1.
