Update routes fails
Oops ;)
Indeed! Substitute self by ZWaveAPI. It's a copy from internal code of Z-Way, where self is ZWaveAPI...
The need of regular Route Updates
Since the update routes function has been repared, I noticed a dramatically improved stability in my Zwave mesh. Before I had quite a few devices marked as dead, which came to live after pressing the check connectivity button. One switch when pressed resulted in all (or a great many other) switches went on. But hard to reproduce. All switches had the same configuration as far I could see from the devices descriptions. After the update routes was repaired, all those strange behaviours have gone, without me doing any changes to device configurations.
As the manual also suggests: It apparantly is important to do an update routes on a regular basis.
Error is occuring again
This morning I got the error Can not write Rules.xml again.
This was a problem on our side. Please try again.
If your config is lost please write us, we will restore it from a backup.
Solved
It works again. Nothing wrong with my configuration. Thanks
