Firmware update option in Device Configuration tab
sdh
Re: Firmware update option in Device Configuration tab
Post by sdh »
Interview results of one of the devices from the above list (device 18). NodeInfoFrame shows command 122, Interview results do not show Firmware Update CC and no firmware option shown.
No Firmware Update CC in Interview Results
device 18 IR.tiff (105.9 KiB) Viewed 15340 times
For the doors/windows sensor, the interview results do show Firmware Update CC.
device 23 IR.tiff (497.55 KiB) Viewed 15340 times
No all Fibaro devices supports/announce FW Update feature. And so far they have not shared any f/w to upload. So, this is not yet useable feature of Z-Way. Only few devices supports OTA (firmware upgrade Over-The-Air), and even less have firmwares published ;)
pofs
Post by pofs »
@sdh Please grep your log for lines like "Node 18:0 supports CC" (where 18 is node id, 0 is default instance) and see if there's FirmwareUpdate mentioned among them.
sdh
Post by sdh »
I only see for device 23:
[2014-05-24 07:28:51.796] Node 23:0 CC FirmwareUpdate Interview done
Rest of the fibaro devices do show it but they are all version 2.1 or more.
sdh
Post by sdh »
After Force re-interview, all my devices show firmware option. Next question is how to perform firmware update. What values go in the 4 fields. I could not find any documentation on that.
pofs
Post by pofs »
sdh wrote:After Force re-interview, all my devices show firmware option. Next question is how to perform firmware update. What values go in the 4 fields. I could not find any documentation on that.
Just leave it alone for now.
It is impossible to get firmware files from 3rd party vendors at the moment. Also it's only a few vendors who implement this command class in their devices at all. We'll try to arrange for updates with them later.
Z-Wave.me devices are currently not updatable over-the-air, but we're working on it.
Firmware update UI part most likely will be changed soon, so there's no reason to update documentation now.
sdh
Post by sdh »
Fair enough. Would be great if you can pull through Fibaro device updates. Most of their current device can upgrade over air, but not sure how open Fibaro would be for this.
