Problem with Fibaro Motion Sensor...
SolarFlor
Re: Problem with Fibaro Motion Sensor...
Post by SolarFlor »
here we are
[2014-06-29 14:05:14.769] SETDATA devices.7.data.basicType = 4 (0x00000004)
[2014-06-29 14:05:14.769] SETDATA devices.7.data.genericType = 32 (0x00000020)
[2014-06-29 14:05:14.769] SETDATA devices.7.instances.0.data.genericType = 32 (0x00000020)
[2014-06-29 14:05:14.770] SETDATA devices.7.data.specificType = 1 (0x00000001)
[2014-06-29 14:05:14.770] SETDATA devices.7.instances.0.data.specificType = 1 (0x00000001)
[2014-06-29 14:05:14.770] SETDATA devices.7.data.infoProtocolSpecific = 5479424 (0x00539c00)
[2014-06-29 14:05:14.780] SETDATA devices.7.data.deviceTypeString = "Routing Binary Sensor"
[2014-06-29 14:05:14.781] SETDATA devices.7.data.isVirtual = False
[2014-06-29 14:05:14.781] SETDATA devices.7.data.isListening = False
[2014-06-29 14:05:14.781] SETDATA devices.7.data.isRouting = True
[2014-06-29 14:05:14.781] SETDATA devices.7.data.isAwake = False
[2014-06-29 14:05:14.782] SETDATA devices.7.data.optional = True
[2014-06-29 14:05:14.782] SETDATA devices.7.data.isFailed = False
[2014-06-29 14:05:14.782] SETDATA devices.7.data.beam = False
[2014-06-29 14:05:14.783] SETDATA devices.7.data.sensor250 = False
[2014-06-29 14:05:14.783] SETDATA devices.7.data.sensor1000 = False
[2014-06-29 14:05:14.783] SETDATA devices.7.data.neighbours = byte[3]
  ( 01 02 06 )
[2014-06-29 14:05:14.783] SETDATA devices.7.data.manufacturerId = 271 (0x0000010f)
[2014-06-29 14:05:14.783] SETDATA devices.7.data.vendorString = "Fibar Group"
[2014-06-29 14:05:14.784] SETDATA devices.7.data.manufacturerProductType = 2048 (0x00000800)
[2014-06-29 14:05:14.784] SETDATA devices.7.data.manufacturerProductId = 4097 (0x00001001)
[2014-06-29 14:05:14.784] SETDATA devices.7.data.ZWLib = 3 (0x00000003)
[2014-06-29 14:05:14.784] SETDATA devices.7.data.ZWProtocolMajor = 3 (0x00000003)
[2014-06-29 14:05:14.784] SETDATA devices.7.data.ZWProtocolMinor = 67 (0x00000043)
[2014-06-29 14:05:14.785] SETDATA devices.7.data.SDK = "4.55.00"
[2014-06-29 14:05:14.785] SETDATA devices.7.data.applicationMajor = 2 (0x00000002)
[2014-06-29 14:05:14.785] SETDATA devices.7.data.applicationMinor = 6 (0x00000006)
[2014-06-29 14:05:14.785] SETDATA devices.7.data.nodeInfoFrame = byte[16]
  ( 30 84 85 80 8F 56 72 86 70 8E 31 9C EF 30 31 9C )
[2014-06-29 14:05:14.786] SETDATA devices.7.data.ZDDXMLFile = ""
[2014-06-29 14:05:14.786] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-06-29 14:05:14.786] SETDATA devices.7.data.keepAwake = False
[2014-06-29 14:05:14.786] SETDATA devices.7.data.countSuccess = 0 (0x00000000)
[2014-06-29 14:05:14.786] SETDATA devices.7.data.countFailed = 0 (0x00000000)
[2014-06-29 14:05:14.787] SETDATA devices.7.data.queueLength = 0 (0x00000000)
[2014-06-29 14:05:14.787] SETDATA devices.7.instances.0.data.dynamic = False
[2014-06-29 14:05:14.787] SETDATA devices.7.instances.0.data.genericType = 32 (0x00000020)
[2014-06-29 14:05:14.787] SETDATA devices.7.instances.0.data.specificType = 1 (0x00000001)
[2014-06-29 14:05:14.787] SETDATA devices.7.instances.0.commandClasses.48.data = Empty
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.supported = Empty
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.supported = True
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.version = Empty
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.security = Empty
[2014-06-29 14:05:14.788] SETDATA devices.7.instances.0.commandClasses.48.data.security = False
[2014-06-29 14:05:14.789] SETDATA devices.7.instances.0.commandClasses.48.data.interviewDone = Empty
[2014-06-29 14:05:14.789] SETDATA devices.7.instances.0.commandClasses.48.data.interviewCounter = Empty
[2014-06-29 14:05:14.789] SETDATA devices.7.instances.0.commandClasses.48.data.interviewDone = False
[2014-06-29 14:05:14.789] SETDATA devices.7.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2014-06-29 14:05:14.789] SETDATA devices.7.instances.0.commandClasses.48.data.typemask = Empty
[2014-06-29 14:05:14.790] SETDATA devices.7.instances.0.commandClasses.48.data.supported = True
[2014-06-29 14:05:14.790] SETDATA devices.7.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2014-06-29 14:05:14.790] SETDATA devices.7.instances.0.commandClasses.48.data.security = False
[2014-06-29 14:05:14.790] SETDATA devices.7.instances.0.commandClasses.48.data.interviewDone = True
[2014-06-29 14:05:14.811] Node 7:0 CC SensorBinary Interview done
[2014-06-29 14:05:14.811] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2014-06-29 14:05:14.812] SETDATA devices.7.data.keepAwake = False
[2014-06-29 14:05:14.812] Interview for Node #7 finished.
[2014-06-29 14:05:14.812] SETDATA devices.7.instances.0.commandClasses.48.data.interviewCounter = 9 (0x00000009)
[2014-06-29 14:05:14.812] SETDATA devices.7.instances.0.commandClasses.48.data.typemask = 268509697 (0x10012201)
[2014-06-29 14:05:14.812] SETDATA devices.7.instances.0.commandClasses.48.data.1 = Empty
[2014-06-29 14:05:14.813] SETDATA devices.7.instances.0.commandClasses.48.data.1.sensorTypeString = Empty
[2014-06-29 14:05:14.813] SETDATA devices.7.instances.0.commandClasses.48.data.1.sensorTypeString = "General purpose"
[2014-06-29 14:05:14.813] SETDATA devices.7.instances.0.commandClasses.48.data.1.level = Empty
[2014-06-29 14:05:14.813] SETDATA devices.7.instances.0.commandClasses.48.data.1.level = False
[2014-06-29 14:05:14.813] SETDATA devices.7.instances.0.commandClasses.49.data = Empty
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.supported = Empty
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.supported = True
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.version = Empty
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.security = Empty
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.security = False
[2014-06-29 14:05:14.814] SETDATA devices.7.instances.0.commandClasses.49.data.interviewDone = Empty
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.interviewCounter = Empty
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.interviewDone = False
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.typemask = Empty
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.supported = True
[2014-06-29 14:05:14.815] SETDATA devices.7.instances.0.commandClasses.49.data.version = 5 (0x00000005)
[2014-06-29 14:05:14.816] SETDATA devices.7.instances.0.commandClasses.49.data.security = False
[2014-06-29 14:05:14.816] SETDATA devices.7.instances.0.commandClasses.49.data.interviewDone = True
[2014-06-29 14:05:14.816] Node 7:0 CC SensorMultilevel Interview done
[2014-06-29 14:05:14.816] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2014-06-29 14:05:14.817] SETDATA devices.7.data.keepAwake = False
[2014-06-29 14:05:14.817] Interview for Node #7 finished.
[2014-06-29 14:05:14.817] SETDATA devices.7.instances.0.commandClasses.49.data.interviewCounter = 9 (0x00000009)
[2014-06-29 14:05:14.817] SETDATA devices.7.instances.0.commandClasses.49.data.typemask = byte[1]
  ( 05 )
[2014-06-29 14:05:14.818] SETDATA devices.7.instances.0.commandClasses.49.data.1 = Empty
[2014-06-29 14:05:14.818] SETDATA devices.7.instances.0.commandClasses.49.data.1.sensorTypeString = Empty
[2014-06-29 14:05:14.818] SETDATA devices.7.instances.0.commandClasses.49.data.1.sensorTypeString = "Temperature"
[2014-06-29 14:05:14.818] SETDATA devices.7.instances.0.commandClasses.49.data.1.val = Empty
[2014-06-29 14:05:14.818] SETDATA devices.7.instances.0.commandClasses.49.data.1.val = 26.200001
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.deviceScale = Empty
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.scale = Empty
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.scaleString = Empty
[2014-06-29 14:05:14.819] SETDATA devices.7.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2014-06-29 14:05:14.820] SETDATA devices.7.instances.0.commandClasses.49.data.3 = Empty
[2014-06-29 14:05:14.820] SETDATA devices.7.instances.0.commandClasses.49.data.3.sensorTypeString = Empty
[2014-06-29 14:05:14.820] SETDATA devices.7.instances.0.commandClasses.49.data.3.sensorTypeString = "Luminiscence"
[2014-06-29 14:05:14.820] SETDATA devices.7.instances.0.commandClasses.49.data.3.val = Empty
[2014-06-29 14:05:14.820] SETDATA devices.7.instances.0.commandClasses.49.data.3.val = 39.000000
[2014-06-29 14:05:14.821] SETDATA devices.7.instances.0.commandClasses.49.data.3.deviceScale = Empty
[2014-06-29 14:05:14.821] SETDATA devices.7.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2014-06-29 14:05:14.821] SETDATA devices.7.instances.0.commandClasses.49.data.3.scale = Empty
[2014-06-29 14:05:14.821] SETDATA devices.7.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2014-06-29 14:05:14.822] SETDATA devices.7.instances.0.commandClasses.49.data.3.scaleString = Empty
[2014-06-29 14:05:14.822] SETDATA devices.7.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2014-06-29 14:05:14.822] SETDATA devices.7.instances.0.commandClasses.49.data.19 = Empty
[2014-06-29 14:05:14.822] SETDATA devices.7.instances.0.commandClasses.49.data.19.sensorTypeString = Empty
[2014-06-29 14:05:14.822] SETDATA devices.7.instances.0.commandClasses.49.data.19.sensorTypeString = "Tank Capacity"
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.val = Empty
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.val = 1.000000
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.deviceScale = Empty
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.deviceScale = 1 (0x00000001)
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.scale = Empty
[2014-06-29 14:05:14.823] SETDATA devices.7.instances.0.commandClasses.49.data.19.scale = 1 (0x00000001)
[2014-06-29 14:05:14.824] SETDATA devices.7.instances.0.commandClasses.49.data.19.scaleString = Empty
[2014-06-29 14:05:14.824] SETDATA devices.7.instances.0.commandClasses.49.data.19.scaleString = "cbm"
[2014-06-29 14:05:14.824] SETDATA devices.7.instances.0.commandClasses.86.data = Empty
This is the log after start. We need to see the log where it appeared for the first time.
SolarFlor
Post by SolarFlor »
This was the first time. If you see at the end of the posted rows you can find it
This is the data loaded from disk, not coming from Z-Wave. We need it's first appearance due to RECEIVED: XX XX XX line
SolarFlor
Post by SolarFlor »
I will check again.
Another question.
Do you know is with our Razberry we can receive information regarding acceleration?
I would like to receive a status (on/off) if the sensor is recording a vibration (acceleration). I set the parameter 20
and infact the sensor is able to react to vibration (it start to lighting) but the status will not change on Z-Way.
20. TAMPER SENSITIVITY
The parameter determines the chages in forces acting on the Fibaro Motion Sensor resulting in tamper alarm beig reported - g-force acceleration.
Available settigs: 0 - 122 (0.08 - 2g; multiply by 0.016g; 0 = tamper inactive)
Default setting: 15 (0.224g)
Parameter size: 1 [byte]
SolarFlor
Post by SolarFlor »
Today I have seen that my Fibaro Motion Sensor generated 13 outputs but only 3 a real ones (presence, tempertaure, lux).
Have you experienced the same phenomena?
There is a way to remove in UI Expert and UI Automation all the useless outputs?
SolarFlor
Post by SolarFlor »
Very Very strange
now even my Fibaro Plug (device called Giorgio) is showing strange outputs. It is like the Fibaro Motion Sensor has 'contamineted' the plug as well.
How I could clean all the false signals?
Natisha Muros
Post by Natisha Muros »
The printing in china have the good sources about the printing products,you can have a look at
Lumberjack
Post by Lumberjack »
I concur with the finding that the amount of devices is growing quickly on the Fibaro motion sensor. In only 6 hours after inclusion I have 2 new sensors... One is distance and the other is unnamed:
Screenshot 2014-07-31 18.48.58.png (49.17 KiB) Viewed 14785 times
Lumberjack
And 3 more over the last 18 hours...
Screenshot 2014-08-01 12.15.46-small.jpg (29.19 KiB) Viewed 14508 times
