Spurious data readings FGBS 001 in v200rc8
Re: Spurious data readings FGBS 001 in v200rc8
Until recently I wasn't aware that OR was running on my Pi. I do run it on Synology NAS, and use Raspberry solely as a Z-Wave gateway. I also never knowingly place an OpenRemote model on the Pi.
I will look into one of my backup images to see what OR was actually running.
The spurious data readings occasionally re-occur. This morning again. As a matter of fact I have two of these FUS devices. These are device[13] and device[15]. This morning I discovered that at about the same time both devices gave temperatures which are widely out of range: 29502.449219, 7549762.000000
[2014-11-21 05:38:28.885] [I] [zway] Removing job: SensorMultilevel V1-4 Get
[2014-11-21 05:38:28.932] [D] [zway] RECEIVED: ( 01 12 00 04 00 0F 0C 60 0D 03 00 31 05 01 44 00 2D 04 65 B9 )
[2014-11-21 05:38:28.932] [D] [zway] SENT ACK
[2014-11-21 05:38:28.932] [D] [zway] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-11-21 05:38:28.933] [D] [zway] SETDATA devices.15.instances.3.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2014-11-21 05:38:28.934] [D] [zway] SETDATA devices.15.instances.3.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-11-21 05:38:28.934] [D] [zway] SETDATA devices.15.instances.3.commandClasses.49.data.1.val = 29502.449219
[2014-11-21 05:38:28.937] [D] [zway] SETDATA devices.15.instances.3.commandClasses.49.data.1.scaleString = "°C"
[2014-11-21 05:38:28.938] [D] [zway] SETDATA devices.15.instances.3.commandClasses.49.data.1 = Empty
[2014-11-21 05:38:29.068] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2014-11-21 05:38:29.071] [D] [zway] SENDING (cb 0xe5): ( 01 0D 00 13 0D 06 60 0D 00 04 31 04 25 E5 76 )
[2014-11-21 05:38:29.074] [D] [zway] RECEIVED ACK
[2014-11-21 05:38:29.077] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-11-21 05:38:29.077] [D] [zway] SENT ACK
[2014-11-21 05:38:29.077] [D] [zway] Delivered to Z-Wave stack
[2014-11-21 05:38:29.090] [D] [zway] RECEIVED: ( 01 05 00 13 E5 00 0C )
[2014-11-21 05:38:29.090] [D] [zway] SENT ACK
[2014-11-21 05:38:29.091] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
[2014-11-21 05:38:29.091] [D] [zway] SETDATA devices.13.data.lastPacketInfo.delivered = True
[2014-11-21 05:38:29.091] [D] [zway] SETDATA devices.13.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-11-21 05:38:29.091] [D] [zway] SETDATA devices.13.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2014-11-21 05:38:29.091] [D] [zway] SETDATA devices.13.data.lastPacketInfo = **********
[2014-11-21 05:38:29.091] [D] [zway] SendData Response with callback 0xe5 received: received by recipient
[2014-11-21 05:38:29.092] [D] [zway] SETDATA devices.13.data.lastSend = 4205984 (0x00402da0)
[2014-11-21 05:38:29.092] [D] [zway] Job 0x13 (SensorMultilevel V1-4 Get): success
[2014-11-21 05:38:29.092] [I] [zway] Removing job: SensorMultilevel V1-4 Get
[2014-11-21 05:38:29.100] [D] [zway] RECEIVED: ( 01 12 00 04 00 0D 0C 60 0D 04 00 31 05 01 44 2D 00 05 B6 6E )
[2014-11-21 05:38:29.100] [D] [zway] SENT ACK
[2014-11-21 05:38:29.101] [D] [zway] SETDATA devices.13.data.lastReceived = 0 (0x00000000)
[2014-11-21 05:38:29.101] [D] [zway] SETDATA devices.13.instances.4.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2014-11-21 05:38:29.102] [D] [zway] SETDATA devices.13.instances.4.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-11-21 05:38:29.103] [D] [zway] SETDATA devices.13.instances.4.commandClasses.49.data.1.val = 7549762.000000
[2014-11-21 05:38:29.106] [D] [zway] SETDATA devices.13.instances.4.commandClasses.49.data.1.scaleString = "°C"
[2014-11-21 05:38:29.106] [D] [zway] SETDATA devices.13.instances.4.commandClasses.49.data.1 = Empty
[2014-11-21 05:38:29.514] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2014-11-21 05:38:29.519] [D] [zway] SENDING (cb 0xe6): ( 01 0D 00 13 0D 06 60 0D 00 03 31 04 25 E6 72 )
[2014-11-21 05:38:29.522] [D] [zway] RECEIVED ACK
[2014-11-21 05:38:29.525] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-11-21 05:38:29.525] [D] [zway] SENT ACK
[2014-11-21 05:38:29.525] [D] [zway] Delivered to Z-Wave stack
[2014-11-21 05:38:29.538] [D] [zway] RECEIVED: ( 01 05 00 13 E6 00 0F )
[2014-11-21 05:38:29.539] [D] [zway] SENT ACK
[2014-11-21 05:38:29.539] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
In addition to the previous post, I found extremely high instances numbers with device 13 (which could not complete the interview for Alarms). See code below. I found several others for this same device
[2014-11-20 17:40:20.130] [D] [zway] SETDATA devices.13.instances.57.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-11-20 17:40:20.131] [D] [zway] SETDATA devices.13.instances.57.commandClasses.49.data.1.scaleString = Empty
[2014-11-20 17:40:20.131] [D] [zway] SETDATA devices.13.instances.57.commandClasses.49.data.1.scaleString = "°C"
[2014-11-20 17:40:20.131] [D] [zway] SETDATA devices.13.instances.84.data = Empty
[2014-11-20 17:40:20.131] [D] [zway] SETDATA devices.13.instances.84.data.dynamic = Empty
The graph below covers the period from 2014-12-01 till 2015-02-09. In this larger timeframe the "mis" readings seem to come in bursts. Maybe external influences?
Even the smallest dots near the bottom line do represent unrealistic environment temperatures of hundreds of degrees centigrade
