EZMotion PIR detector - any success?
Lumberjack
Re: EZMotion PIR detector - any success?
Post by Lumberjack »
I 'solved' this by monitoring the Z-Way logs and trapping a signature that looks like:
01 09 00 04 00 xx 03 20 01 yy
where xx = the device id in hex and yy is the level in hex (yy == 0 means motion stopped, yy == FF means motion started)
These messages seem correctly formatted and are identical to e.g. the Everspring and Fibaro ones (provided BASIC ON/OFF is configured for the latter one). I am therefor puzzled they are not picked up correctly specifically for this device. Perhaps something is wrong in the ZDDX file? The motion instance shows as 'Generic' where the Fibaro one shows 'General Purpose' as Device Type in the Expert GUI.
I am looking at using the new HomeAutomation functionality for trigger management. I am not able to use it since it does not pick up the motion via the Z-Way stack. I have 5 of these devices at 70 EUR each so bit too expensive to replace, plus they work nicely with pets in the house since they don't detect motion below a certain height and can be powered via USB. So would be greatly appreciated if this could be fixed.
Lumberjack
Checked device types of the different motion sensors mentioned and it seems the Everspring and Fibaro sensors report as device type 'Binary sensor' whereas the EZMotion reports as 'Multilevel sensor'. Raw Z Wave messages sent on motion detection seem identical though. Wrong device type detected/used?
Also, the value 0 for Level in the expert UI seems incorrect when dealing with a motion sensor. The other two report 'idle' and 'triggered'. See screenshot below.
Screenshot of expert GUI with three motion sensor types
EZMotion problem.png (70.79 KiB) Viewed 13614 times
pofs
Post by pofs »
Some Basic reports are also triggering Sensor Binary state changes inside z-way (for some special device classes), so you can see it for other sensors.
But they're never mapped to Multilevel Sensor states, so you don't see anything on EZMotion when Basic arrives. Even more, Basic report arrives for default channel, while Mutlilevel Sensor is located on a non-default one. There's simply no way it can be mapped automatically.
It is actually a pretty good question why it identifies as Multilevel sensor. And I don't have a reasonable answer to it.
Nevertheless, you can still handle Basic report in JS code and invoke explicit Get() for correct channel and command class.
Lumberjack
pofs, thanks for your quick reply. Some questions remain.
Is this something the device reports itself, or is this something provided by metadata such as the ZDDX file? Is there a means to change this into 'Sensor Binary' by changing an XML file?
Hoping you can tell me how. I was using the 'Data logging' module in the HA software to trigger on level change, but that seems to fire not at all or too many times (besides always having value 0), whereas my 'log monitoring' works 100% correct.
I would love to throw my log monitoring code out for your nice HA JS implementation which looks great, but cannot due to this one sensor problem.
pofs
Post by pofs »
That is something the device reports itself. XMLs are mostly for a nice device picture and fancy parameter names, while device capabilities are determined by its NIF.
Try something like:
var dev = zway.devices[7];
dev.Basic.data.level.bind(function(type) {
    if ((type & 0x3F) == 0x01) {
        dev.instances[1].SensorMultilevel.Get();
        // or just dev.SensorMultilevel.Get(), not sure - try both
Lumberjack
Thanks for the example. I decided to try it out with a sensor that normally works fine (The everspring, device 5):
zway.devices[5].Basic.data.level.bind(function(type) {
   console.log("fired zway.devices[5].Basic.data.level");
No 'fired' message when I triggered the motion sensor. Same for device 7 (the EZMotion).
However, this works just fine on the everspring:
zway.devices[5].instances[0].commandClasses[48].data[1].level.bind(function(type) {
   console.log("fired zway.devices[5].instances[0].commandClasses[48].data[1]");
Which printed:
[2015-04-03 01:33:56.418] [I] [core] fired zway.devices[5].instances[0].commandClasses[48].data[1]
as expected.
I did another simple test on the EZMotion (device 7) by asking for any changes after a certain timestamp. I started with state 'Idle' and triggered motion.
Then I asked for any changes since the last date by issuing: http://10.0.0.11:8083/ZWaveAPI/Data/1428017861, and I got only this change back (cut out only 'devices.7.*'):
devices.7.data.lastReceived: {
value: 0,
type: "int",
invalidateTime: 1421504307,
updateTime: 1428017954
which is of no value, since the value is always 0, whether triggered or idle.
Any suggestions how to proceed?
Note: I am on v2.0.0
