Backup/restore functionality not working [fixed v2.0.1-rc12]
Re: Backup/restore functionality not working
@mhorst
Did you resolve this in the meantime?
Users in the Quad Core Raspberry thread report similar issues. They blame it on a newer Rasbian release 3.18.5-v7 that they use. Which version do you have?
Mirar
Post by Mirar »
Worked fine for me. Did they fix it?
100%[======================================================================================================>] 13,211,566  2.72M/s   in 5.2s
2015-02-05 10:33:40 (2.45 MB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.0.1-rc12.tgz' saved [13211566/13211566]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: done.
Making backup of previous version of Z-Way in /opt/z-way-server_2015-02-05-10-34-00
Copying settings
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LC_PAPER = "sv_SE.UTF-8",
        LC_ADDRESS = "sv_SE.UTF-8",
        LC_MONETARY = "sv_SE.UTF-8",
        LC_NUMERIC = "sv_SE.UTF-8",
        LC_TELEPHONE = "sv_SE.UTF-8",
        LC_IDENTIFICATION = "sv_SE.UTF-8",
        LC_MEASUREMENT = "sv_SE.UTF-8",
        LC_TIME = "sv_SE.UTF-8",
        LC_NAME = "sv_SE.UTF-8",
        LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-02-05 10:34:04--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 408241 (399K) [application/x-gzip]
Saving to: `STDOUT'
100%[======================================================================================================>] 408,241      439K/s   in 0.9s
2015-02-05 10:34:05 (439 KB/s) - written to stdout [408241/408241]
Stoping zbw_connect:ok.
zbw_connect patched
Starting zbw_connect:ok.
Getting webserver mongoose for Webif
--2015-02-05 10:34:06--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[======================================================================================================>] 44,749      --.-K/s   in 0.1s
2015-02-05 10:34:06 (319 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Stopping mongoose http server
Adding mongoose to autostart
        LANGUAGE = (unset),
        LC_ALL = (unset),
Start mongoose http server
Opened config/zddx/dcd71b22-DevicesData.xml
Opened config/zddx/e8e76e50-DevicesData.xml
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
mhorst
Post by mhorst »
Looks like it was fixed. I installed v2.0.1-rc12, which succeeded, and after that I was able to backup and restore settings. Even if I do a Factory Reset in between, the restore functionality works.
Thank you developers. This gives me enough confidence to start migrating the rest of the z-wave devices in my home to the Razberry.
SolarFlor
Re: Backup/restore functionality not working [fixed v2.0.1-r
Post by SolarFlor »
when the version 2.0.1 will be released?
SolarFlor wrote:when the version 2.0.1 will be released?
As always when they think it is ready ;)
I guess they will, once the firmware updates (e.g. for UZB1) are reliable enough to be released.
johnhepburn
Post by johnhepburn »
So I hade the same problem. I had corrupt SD card and had to reinstall from scratch. I originally used v2.0 but it would not restore my backup. I read this thread and reinstalled v2.0.1-rc12 and the backup installed fine. I can see all my devices and now the friendly names and zones in old blue. The problem now, none of the devices respond to switch commands, or anything at all. I thought I would try and re interview a simple lamp module and see if that would solve the problem. I got some weird results! I included a screen cap, does anyone understand this? Or what I should do next?
John
Screen Shot 2015-03-16 at 6.51.18 PM.png (111.96 KiB) Viewed 16559 times
johnhepburn
Bump, anyone? :D
markknijnenburg
Post by markknijnenburg »
I'm having the same problem restoring my network to a new RazBerry Gen5 (backup from Gen3) - I've tried 2.0.1 release and 2.0.2-rc1 but all I see are two devices which fail to interview (my network consists of over 70 devices and the backup file shows all of them). I want to give 2.0.1-rc12 or rc15 a try as it seems that people have had more luck restoring using these versions, however they are no longer available online. Has anyone got a link to one of these versions for me?
thaui
Post by thaui »
I had the same problem with several builds. I will use 2.0.1-RC3. Seems to be working. Pls. Try and report.
markknijnenburg
Hi Thaui - any chance I could get a copy of 2.0.1 RC3 from you?
Locked
