ZWay 2.2.0 with Netatmo?!
Re: ZWay 2.2.0 with Netatmo?!
@nord problem fixed, you can test it: update from online apps
Minux
Post by Minux »
Hello, how can i get this module ? I don"t see it in my module app list.
You should see it in Online apps list
Minux
Post by Minux »
i don't see it.
I need add specific token in "App Store Access" ?
@PoltoS, I don't see the Netatmo app either in the online store (using final v2.2.4) Could it be that the author has submitted a new version for evaluationj? I did notice in the past that in such a situation I did not see my modules in the online app store
Apologize, something went wrong, it was hidden. Now it is back
Minux
Post by Minux »
ok, i see it thanks.
fundy
Post by fundy »
Some comments to the current version:
1. for some strange reason it does not create respective sensors for any netatmo NAModule4 type (additional indoor module) /temp,humidity, co2/ while parsing the netatmo weather station data
2. fails to update data from wind gauge sensors. The log is flooded with "error updating device" with regard to all wind gauge sensors. The data is in api OK however
3. script uses obsolete netatmo weather station API method "devicelist" that is now deprecated, instead of "getstationsdata". (This may be the reason of the problem No. 2 I guess)
I just fixed a minir bug in the device (auth problem after an hour). Will try to ask original developers to check it. I've no NetAtmo to test.
fundy
Post by fundy »
Thanks. I have a full set of netatmo weather station to test it on. However I have no access to current sources. I've seen previous versions in this forum only. I'm on POPP HUB2 Zway with no shell access so far... If you or the original devs could uplod the netatmo module source somewhere it might be much easier for me to help to debug it.
