Can door sensor trigger audio on Raspberry Pi
Re: Can door sensor trigger audio on Raspberry Pi
The simplest is to master it from the terminal (bash), make a bash script that will produce the desired sound and then run it from CodeDevice using system("/your/command") (don' forget to add it in the .syscommands file).
