Bug in updating/polling multilevel switches [SOLVED]
jadedeane
Re: Experience with GE switches and status update failures
Post by jadedeane »
I tried turning on the periodical polling app and got some interesting results...
Turned on the lights via the add-on 3-way switch (that doesn't trigger a NIF), Z-Way status "Off" (duh...)
Waited for ~1min for the poller to fire off. When it did, Z-Way debug reported the dimmer percentage levels slowly drop. Basically, when the poller fires off it flips the state of the lights... If I turned the lights on via the add-on switch, Z-Way shuts them off. If I turned the lights off via the add-on switch, Z-Way turns them on.
PS, I haven't been drinking but wish I were... might explain the above ;-)
jadedeane
Post by jadedeane »
Noticed in the debug that when the poller fires off to snag updates (I see the SwitchMultilevel Get job, presume that's the update request?) there's also a "SwitchMultilevel Set" job. Seems odd anything but a "get" for an update would go out. I don't see sets for the binary switches, just multilevel.
Screen Shot 2016-08-19 at 3.37.16 PM.png (61.36 KiB) Viewed 14803 times
NK5P
Post by NK5P »
I have the exact same experience. What I have been able to figure out is that a SET command gets sent to multilevel switches before the GET does. The SET level seems to be whatever the last known value of the dimmer is. If the UI shows that the dimmer is off and someone has turned the dimmer on locally the dimmer will be turned off on the next polling event. This happens when you manually update from the regular UI (by clicking the icon) and using the Periodical Switch Polling app.
Clicking the update button in the expert UI only sends a GET.
This only happens on multilevel switches, binary switches only send a GET.
jadedeane
Post by jadedeane »
I opened an issue on GitHub, and added logging messages from a poller run, https://github.com/Z-Wave-Me/home-automation/issues/373.
jadedeane
Re: Bug in updating/polling multilevel switches
Post by jadedeane »
Job queue when pressing "update" in the standard UI:
Screen Shot 2016-08-21 at 5.14.37 PM.png (39.5 KiB) Viewed 14779 times
Job queue when pressing "update" in the expert UI:
Screen Shot 2016-08-21 at 5.15.29 PM.png (34.49 KiB) Viewed 14779 times
here is a fix. We will add it to the next release
https://github.com/Z-Wave-Me/home-autom ... -241334212
jadedeane
Post by jadedeane »
Confirmed working. Thank you!
Locked
