Door/Window magnetic sensors
04greg1980
Re: Door/Window magnetic sensors
Post by 04greg1980 »
Thanks for your help.
I have tried different think into HC2 with 4.100 version, but no success.
Here you can see in this picture that HC2 don't recognize the z-uno module correctly.
Capture d’écran 2016-10-15 à 23.12.23.png (111.26 KiB) Viewed 9590 times
HC2 propose to download the template:
Capture d’écran 2016-10-15 à 23.12.41.png (335.92 KiB) Viewed 9590 times
And the template is:
  • <?xml version="1.0" encoding="utf-8"?>
    <Zwave version="10" xmlns:vc="http://www.w3.org/2007/XMLSchema-versioning" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://production-server.fibaro.com/xml ... endPointID id="0" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro>com.fibaro.motionSensor</typeFibaro><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface><interface>Configuration</interface><interface>Association</interface><interface>MultiChannelAssociation</interface><interface>FirmwareUpdate</interface><interface>AssociationGrpInfo</interface><interface>Powerlevel</interface><interface>ZwaveRoutingSlave</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ASSOCIATION_GRP_INFO" nowConfigure="true"><valueHashes><value index="1" type="bool"><name>dynamicInfo</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_DEVICE_RESET_LOCALLY"><valueHashes/></commandClass><commandClass cmdClass="COMMAND_CLASS_ZWAVEPLUS_INFO" version="2" nowConfigure="true"><valueHashes><value index="1" type="byte"><name>zwavePlusVersion</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value><value index="2" type="byte"><name>roleType</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value><value index="3" type="byte"><name>nodeType</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value><value index="4" type="int"><name>InstallerIconType</name><typeFibaro/><interfaceFibaro/><max>9223372036854775807</max><min>-9223372036854775808</min><virtual>0</virtual></value><value index="5" type="int"><name>UserIconType</name><typeFibaro/><interfaceFibaro/><max>9223372036854775807</max><min>-9223372036854775808</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_MULTI_CHANNEL" version="4"><valueHashes><value index="1" type="byte"><name>endPoints</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value><value index="2" type="bool"><name>dynamic</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="3" type="bool"><name>identical</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="4" type="JSONObject"><name>aggregatedEndPoints</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual><json>{"endPointCount":0}</json></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_CONFIGURATION" nowConfigure="true"><valueHashes><value index="1" type="configuration"><name>parameters</name><typeFibaro/><interfaceFibaro>zwaveConfiguration</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>1</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>1</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="2"><valueHashes/></commandClass><commandClass cmdClass="COMMAND_CLASS_POWERLEVEL"><valueHashes/></commandClass><commandClass cmdClass="COMMAND_CLASS_FIRMWARE_UPDATE_MD" version="3"><valueHashes><value index="1" type="firmwareUpdate"><name>firmware</name><typeFibaro/><interfaceFibaro>fibaroFirmwareUpdate</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="2" type="JSONArray"><name>firmwareVersion</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual><json>[]</json></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ASSOCIATION" version="2"><cmdCAssociation bitAddressable="false"><associationGroup number="1" maxNode="5" setAuto="true" maxMultiNode="5" setMultiAuto="true"><description><lang tr="EN"/></description></associationGroup><associationGroup number="2" maxNode="5" setAuto="true" maxMultiNode="5" setMultiAuto="true"><description><lang tr="EN"/></description></associationGroup></cmdCAssociation><valueHashes><value index="1" type="association"><name>associations</name><typeFibaro/><interfaceFibaro>zwaveAssociation</interfaceFibaro><max>255</max><virtual>0</virtual></value><value index="2" type="int"><name>associationGroups</name><typeFibaro/><interfaceFibaro>zwaveAssociation</interfaceFibaro><max>9223372036854775807</max><min>-9223372036854775808</min><virtual>0</virtual></value><value index="3" type="byte"><name>currentActiveGroup</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_VERSION" version="2"><valueHashes/></commandClass><commandClass cmdClass="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="3"><valueHashes><value index="1" type="byte"><name>supportedGroupings</name><typeFibaro/><interfaceFibaro>zwaveMultiChannelAssociation</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="1" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="2" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="3" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="4" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="5" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="6" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="7" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="8" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="9" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID><endPointID id="A" enabled="true" visible="true"><genericClass>7</genericClass><specificClass>1</specificClass><typeFibaro/><interfacesFibaro/><interfaces><interface>Basic</interface><interface>BinarySensor</interface></interfaces><commandClasses><commandClass cmdClass="COMMAND_CLASS_BASIC"><valueHashes><value index="1" type="byte"><name>value</name><typeFibaro/><interfaceFibaro/><max>255</max><min>0</min><virtual>0</virtual></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_SENSOR_BINARY" version="2"><valueHashes><value index="1" type="bool"><name>value</name><typeFibaro/><interfaceFibaro/><virtual>1</virtual></value><value index="10" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass><commandClass cmdClass="COMMAND_CLASS_ALARM" version="5"><setNotifications><notificationType name="Access Control" id="6" enable="true"/></setNotifications><valueHashes><value index="100" type="byte"><name>alarmType</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="101" type="byte"><name>alarmLevel</name><typeFibaro/><interfaceFibaro>zwaveAlarm</interfaceFibaro><max>255</max><min>0</min><virtual>0</virtual></value><value index="1558" type="bool"><name>Window/Door is open</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="1559" type="bool"><name>Window/Door is closed</name><typeFibaro/><interfaceFibaro/><virtual>0</virtual></value><value index="65536" type="bool"><name>value</name><typeFibaro>com.fibaro.doorSensor</typeFibaro><interfaceFibaro/><virtual>1</virtual><functionalityDescr>doorSensor</functionalityDescr></value></valueHashes></commandClass></commandClasses></endPointID></endPoint></Zwave>
Can you help me?
Thanks a lot
See you soon
Greg
04greg1980
Hello
With the new fibaro firmware, all is running.
But I have only one error again : the Door has open state when the captor is closed and close state when the captor is opened .
Do you Know how i CAN change that ?
Thanks a lot
Greg
Why not to invert the reported value in the getter? instead of
return val;
do
return !val;
