Please share example .ino with multiple DS18B20?
michap
Re: Please share example .ino with multiple DS18B20?
Post by michap »
In 2.07 will be a 1Wire scanner (will scan for 18B20 addresses) and the array issue is fixed.
So you can replace soon the sketch with the new sample code ;)
Michael
A.Harrenberg
Post by A.Harrenberg »
n0ir wrote: Thank you! The sketch you uploaded seems to work! :) I'm really thankful for your help. Maybe your sketch could be featured in the https://z-uno.z-wave.me/examples/ to help other users? I assume there must be several other users who want to use the Z-Uno with multiple temperature sensors?
no problem. The funny thing is that yesterday evening the beta 2.07 was released and from the description it will work with multi-dimensional arrays, so I expect that your code will compile and run under 2.07 as well ,-)
So you might want to give it try...
If the new compiler supports the arrays, "your" code style will be much better as an example.
For the Vera stuff I can answer, I don't have one and I don't know how it organizes the devices. I can only say that from my system (fhem) I get a "root"-device e.g. 52 and then "children" 52.01, 52.02, ... where the functions of the first child 52.01 are also mirrored into the root device.
Regards,
Andreas.
n0ir
Post by n0ir »
Does this new FW means that you won't have to specify the DSB1820 ID:s? HOw do I update the Z-Uno to 2.07? Is that the same as "Burn Bootloader"?
michap
Post by michap »
n0ir wrote:HOw do I update the Z-Uno to 2.07?
See the topic from PoltoS https://forum.z-wave.me/viewtopic.php?f=3427&t=24150
After updating software you must burn a new bootloader.
Yes, ID's will be detected then.
I would wait a little bit - if you want to be sure - it is a release candidate only - and the samples are not online just now.
Michael
A.Harrenberg
yes, waiting a litte seems to be a good idea as it seems that there are some issues with 2.07 that are not fully explained...
I have a 2.07 now on my normal machine but can go back to 2.06 on a linux server or on my laptop...
Regards,
Andreas.
n0ir
Post by n0ir »
Not having to manually define the sensor ID would be very helpful. The DS18B20 probes I want to read is connected to warm water tanks, and I can't reach them easily. I will wait until stable FW 2.07 and try again. Maybe there will then also be some better example sketches from Z-Uno manufacturer.
michap
Post by michap »
With 2.07 the provided sample code (in IDE) is working fine ;)
No more needs to define the addresses before - will be scanned.
For debugging via USB edit the line
#define MY_SERIAL Serial
Michael
n0ir
Post by n0ir »
Great! :)
I managed to update to 2.07.
What sketch should I upload to the Z-Uno to automatically scan and send temperatures from multiple DS18B20? I have these examples in IDE:
michap
Post by michap »
"DS18B20Scanner" of course :)
Michael
n0ir
Post by n0ir »
Weird. I have uploaded this example to the Z-Uno but I don't get anything in the serial monitor? I have pressed the reset button after uploading and tried to disconnect the Z-Uno from the computer.
2016-12-16 (1).png (71.77 KiB) Viewed 15843 times
However, am I wrong to assume that that sketch seems to scan for DS18B20 ID:s? I have already found out ID using other sketches. I thought 2.07 would be able to find 1-wire sensors automatically in sketches?
I would like a sketch that automatically find multiple connected DS18B20 and send the values to my controller.
