Can't install apps: "Failed to install the app"
Re: Can't install apps: "Failed to install the app"
CLOSED: Should be fixed with 2.3.0-rc6. Thanks PoltoS for your help and effort.
I have installed right from the start Debian Stretch & Z wave server in a Raspberry pi. I installed the workaround for compatibility Stretch & Z wave server (wget -q -O - support.zwave.eu/libs | sudo bash).
All is working, but when I try to download Online app I have the following error:
SmartHome UI : ERROR
anybody could told me if had the same problem & how did it solved?
Thanks,
Thanks,
Solved.
In case it can help someone.
When defining a static IP through the /etc/dhcpcd.conf file, I could not download the applications from the "Online Apps" section. I had the following error:
I have defined the static IP of my Raspberry in the router and everything works correctly.
Regards,
Regards,
