COMMAND_CLASS_METER_TBL_CONFIG
Re: COMMAND_CLASS_METER_TBL_CONFIG
Hm... It do not answer to half of packets. Please try to edit config/Defaults.xml to change DeviceRelaxTime to 10 or even 15. May be this will help. Just run Interview (no need to re-include)
larekm
Post by larekm »
Hi!
I change DeviceRelaxTime to 15 and restarted the zway-server. The Interview result is now 100% (missed the part with no new inclusuion needed.) But still I can't see any meter values. Attaching log file again. //Lars
inclusion_kamstrup_2.log.zip
(40.24 KiB) Downloaded 1276 times
Makes sense, MeterPulse is the one that reports the values and it was never implemented in the smarthome (nor in expert UI) as it is very rare.
Please apply this fix to the automation/modules/ZWave/index.js: https://github.com/Z-Wave-Me/home-autom ... 1d993af7ca
It was written in 3 minutes in blind, so might not work out of the box. Please try it and debug if you can. If you can't, we can help remotelly.
larekm
Post by larekm »
I updated the index.js and it look like the fix worked.
I got a nod of type PulseMeter which gives me the meter standing of the meter. I know that you can retrieve power and currents from the meter also but this is enough for me.
Many thanks
Lars
