How to make schedule conditional?
micky1500
Re: How to make schedule conditional?
Post by micky1500 »
dependencies.html doesn't work for me.
I get 'Reading device data...' and nothing else. in Chrome and Edge.
The other tools work perfectly :)
Will be using your tool to clean my config.json file.
I suspect after an unexpected power outage, I have corruption. Route Map has stopped working again.
Your tool is showing more devices that don't exist than are actually real..
piet66
Post by piet66 »
PoltoS wrote:
17 Feb 2019 20:13
And one more:
configjson.js:342 Uncaught TypeError: Cannot read property 'forEach' of undefined
at configjson.js:342
at Array.forEach (<anonymous>)
at buildDevArrays (configjson.js:338)
at Object.success (configjson.js:267)
at u (jquery.min.js:2)
at Object.fireWith [as resolveWith] (jquery.min.js:2)
at k (jquery.min.js:2)
at XMLHttpRequest.<anonymous> (jquery.min.js:2)
I tested this function again with my own config and also with the default config.json. Both are working.
There must be a difference in your config in profiles paragraph.
Command: profile.hide_single_device_events.forEach(function(device) {
Must be an (empty) array.
piet66
Post by piet66 »
PoltoS wrote:
17 Feb 2019 20:07
Wow! Nice tool for inspection of the API content.
But I get few errors:
js/dependencies.min.js:1 Uncaught TypeError: Cannot read property 'indexOf' of undefined
at js/dependencies.min.js:1
at Object.success (js/dependencies.min.js:1)
:1 Uncaught TypeError: Cannot read property 'getAttribute' of undefined
at http://192.168.0.32:8083/smarthome/user/MxInfo/:1:249
at Array.sort (native)
at srt (http://192.168.0.32:8083/smarthome/user/MxInfo/:1:147)
at window.onload (http://192.168.0.32:8083/smarthome/user/MxInfo/:1:704)
To get more info about the problem you can change in file dependencies.html the string 'js/dependencies.min.js' into 'js/dependencies.js' and reload the function.
piet66
Post by piet66 »
micky1500 wrote:
17 Feb 2019 22:54
How do you want to do that? My tools don't change anything in the system. I think it's not really necessary. I don't think that removing old devices will help. There's no info about routing in config.json. Don't know where it is stored. You can display some info about device neighbours with zwave_configuration.html. Look at devices/<number>/data/neighbours.
piet66
Post by piet66 »
micky1500 wrote:
17 Feb 2019 22:54
If you want me to look after this problem, I need your device and instance data.
In this case get the data by
http://<your ip>:8083/ZAutomation/api/v1/devices
and
http://<your ip>:8083/ZAutomation/api/v1/instances,
store each in a file and send it.
Which language do you use?
