Can not remove associations in Expert UI
Re: Can not remove associations in Expert UI
Please give us remote access to check it
brusan
Post by brusan »
I'll fix access. Where do I send credentials?
PM
brusan
Post by brusan »
Hi z-wave.me,
Just wanted to say that you don't have to mind about the bug report I sent in to you about two months ago (before opening this thread) and don't mind this thread either. I have simply concluded that z-wave.me customer support is not compatible with the needs of a functioning home. I cannot have a "smart home" that reacts to commands like a dinosaur with long delays due to associations that are no longer valid and other things and consequently not a support organization the possess the same speed of response.
As a consequence of above, I have thrown out the Razberry card and replaced it with a Aeotec Z-stick and installed openHAB as a replacement for z-wave.me. It's been a number of interesting and sometimes frustrating years with z-wave.me but unfortunately, I can no longer trust the function of my home to z-wave.me.
I sincerely hope you will be able to build a professional support function, processes for release of code that involves unit, integration and system testing that avoids regression problems, feature bugs and shaky release cycles but for the time being, I can not wait for that to happen.
Over and out :)
So long, and thanks for all the fish 2 600x337.png (534.11 KiB) Viewed 11482 times
Pitty to read this. We will do our best to improve the service.
Pomidoor
Post by Pomidoor »
So what about this problem ? I have exactly the same case as brusan in first post. After excluding and including again in secure mode WallMote it is not going through with "AssociationGroupInformation". Getting "Aeotec WallMote Quad - Interview is not complete" and from Fibaro Double Switch 2
"- Removed associated devices."
Im checking my options for a working smart home but with z-way Im only getting more and more frustrated :( Please help me to solve this issue @PoltoS
Please write by mail with all details to ps@ and smr@ and we will try to help you.
