remote does not work after update to 3.0.0
frako
Re: remote does not work after update to 3.0.0
Post by frako »
I can't find any entry for z-wave.me in netstat on the pi. So I think there will be no active connection. About z-box-web I can't access, only directly over the ip:8083.
Are you sure you followed the upgrade correctly keeping zbw files? You can always reinstall the remote access (you will get a new id): https://z-wave.me/frequently-asked-ques ... ne-sd-card
frako
Post by frako »
No, I'm really not sure of all these things I've done with the update. It seems to me that I made some mistakes. Now I ran the script from the link and got a new z-box web id. But I can't log in via the z-box-web. Does it possibly have something to do with the following? Is a password file missing in the zbw?
pi@raspberrypi:~ $ /etc/init.d/zbw_connect start
cat: /etc/zbw/passwd: Keine Berechtigung
Didn't find passwd file
pi@raspberrypi:~ $
Have you followed the manual on the page above?
Yes, the file is missing.
frako
Post by frako »
I think so. I've done it with copy and paste and enter.
You can provide us remove access via somthing like AnyDesk.
frako
Post by frako »
I did not install AnyDesk or something else like that. The RealVNC server and ssh is enabled in the settings since I set up the Raspi some month ago. Everything worked well. The only thing I changed was the update of z-way to 3.0.0.
SSH is also ok
frako
Post by frako »
What does that mean? What is to do?
Provide us some access
