Z-Wave v3.1.3 Release
Franz Winchester
Re: Z-Wave v3.1.3 Release
Post by Franz Winchester »
Great, here you can get 100% of no support.
micky1500
Post by micky1500 »
Lol, It does get quiet, maybe they go on holiday.
Downgrade is same as upgrade, just give the version you need.
in the GUI upgrade window, choose "update to" put in v3.1.2
or Linux type:- (edit the string to fix the line wrap mishap)
export BUILD=3.1.2; cd /tmp/ && wget https://storage.z-wave.me/z-way-server/ ... _armhf.deb && sudo dpkg -i z-way-${BUILD}_armhf.deb
I would suggest making both backups before:- A .zbk and a zab file.
Franz Winchester
Tried to downgrade to 3.1.1 via GUI , but no success. 3.1.2 was no option because worse than 3.1.3.
With linux im am not so familiar to understand what to do.
micky1500
Post by micky1500 »
you said. Tried to downgrade to 3.1.1 via GUI , but no success.
in GUI you need to include the 'v' put in v3.1.1
It works every time I've tried.
Franz Winchester
Of course I addede the v. The downgrade starts, but after finishing it's still 3.1.3
Tried it two times.
micky1500
Post by micky1500 »
ok. im sorry
If it is a Pi, please use the following command in the terminal:
The UI should work too
Meanwhile we will check the issue and fix it asap
enbemokel
Post by enbemokel »
Thumbs up ;-)
Franz Winchester
I do not want to downgrade to v3.1.2, it's worse than v3.1.3. v3.1.1 is ok. GUI does not work.
Locked
